My html page doesn't work
    Hello,
    I'm having a problem with my Zee to access custom page. I don't know what I doing wrong.
    When I type this URL: http://IP/test.aspx the browser is "connecting" to the page but doesn't finish loading the page. It seems to be stuck in one process.
    It's the original test file that I didn't changed.
    In the log I see:
    ASP.NET application host created
    Creating ASP.NET application host...
    and that's all.
    What's wrong?
    Hi.
    Did you get any further with this ? I'm having the same problem and can not get the test.aspx script to run.
    As a test I created a simple hello world .html which loaded almost instantly. I renamed it to .aspx and the page never loaded even after retrying many times.
    Phill
      Same here. Rich said there was a change coming to fix an aspx performance issue. I'm hopeful this will fix this issue.
      79 Z-Wave Nodes, 131 Events, 383 Devices
      Z-Wave, UPB, WiFi
      Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
        Great thanks. I'll just hang fire for the update.
        Phill
          Hello,
          I updated today to the last version 3.0.0.55.
          And unfortunatly it doesn't help
          The aspx in VB can't compile (error 500 Thread aborded).
          I compiled a simple aspx in C# (HomeSeer_REST_API.aspx) but everytime I want to execute it later it recompile the file (even if I don't change the file).
          So I rolled back in 3.0.0.47, super !!!!
          I don't want to be unpolite (I know it's not easy to do such product), but I bought a product which was not in Beta, on the documentation it says that it supports the aspx but in reality it is not working, even after 2 updates.
          I really need to know if it will work one day, otherwise I will use another box.
          Thank you.
            Originally posted by Lada View Post
            Hello,
            I don't want to be unpolite (I know it's not easy to do such product), but I bought a product which with not in Beta, on the documentation it says that it support the aspx but in reality it is not working, even after 2 updates.
            Thank you.
            Did you put in a Bugzilla ticket on this issue?
            -Rupp
              No but I will.
                No but I will.
                Thanks. This is the only way for the HST developers to know there's an issue.
                -Rupp
                  I also have upgraded to .55 - I am having intermittent success and occasionally (maybe 1 in 10 times) the .aspx will load but it does take a long time, typically minutes.
                  As a ticket has been raised I'll leave it at that and just watch this thread for updates.
                  Interestingly, if you just try and load a page called "test" with no suffix, you seem to get a response with a homeseer header and footer with the contents full of interesting what look like widgets.
                    Update for Zee
                    Does any one know what the update did?
                    danielbo
