Zee Crashing assistance required.
    Hi. I have my Zee up and running with approximately 15 Z wave devices. The device runs for several hours but at an unknown number of hours after homeseer stops working. Using Putty I can get on the Zee appliance and can't see the 2 homeseer processes or mono running. Peforming /usr/local/homeseer/restart.sh will get the appliance up and running again.
    The homeseer log file only contains information from the last reboot and so I can't see if anything was logged before it stopped working.
    Any ideas of debugging ?
    Phill
    Phil,
    You can end HS3 running on the Zee; then open an SSH window and start Homeseer in the Homeseer sub directory using the ./go command. The putty window should show you some granular details while Homeseer is running.
    - Pete
    Auto mator
    Fanless Intel® Celeron N3160 SoC 8Gb
      Thanks, I'll give it a go.
        Just an FYI relating to a quickie look at another Zee last night and this morning and relating to my Zee setup observation.....the Z-Wave plugin is not plug n play in Linux / Mono and HS3.
        This means you will hang up the Z-Wave plugin running on the Zee if you unplug the USB Aeon stick while Homeseer 3 is running. Disabling and re-enabling the plugin may or may not help. If you want to remove or unplug Aeon stick; disable Z-Wave plugin; then shut down HS3 device; then remove the Aeon Stick; then start up the Zee.
        I am not sure what would cause the Aeon stick to hang up HS3; but guessing if you look at the console SSH window you may see something.
        Here is an example. HS3 is running. I only have a CM11A plugged in:
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        root@ICS-HS3-Zee:~# lsusb
        Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
        Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
        Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
        Bus 001 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
        root@ICS-HS3-Zee:~#
        I hot plugged the Aeon stick and lost the SSH connection. I do not know what else happened.
        I then SSH'd back into the Zee.
        Bus 001 Device 004: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
        Bus 001 Device 005: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
        root@ICS-HS3-Zee:~#
        Now to mess around some more; I can enable the Z-Wave plugin; validate that its working; then unplug the Aeon stick or enable the plugin; shutdown HS3 Zee; unplug the Aeon stick; then startup HS3 with the plugin enabled and no Aeon stick plugged in. It will cause issues.
        - Pete
        Auto mator
          Pete. I'm new to mono and my UNIX skills are old (sun SVR4 and early Solaris). Just wondering, looking at the ./go script, there is a command line argument --Log. I'm just wondering if I could redirect the output to a text file rather than needing an interactive putty session running ? I don't know how long putty runs before timing out ?
            Putty hasn't timed out for me. Yup its already recording it in the log file; such that you can see it there too. Just a live view via SSH.
            Historically though just a guess would be to use the "> file.txt" after the ./go command.
            Just tried this:
            sudo ./go > test.txt
            and I saw everything in the text.txt file.
            Yeah; here not too long ago; well in "dog" years recall replicating a Sun Solaris system at work to figure it out to upgrade it to talk to a newer switch from a very old network hub in a transitional migration of an old broadband FIDs display. There was a few times during the endeavor that I just walked away from it as it was too cryptic for me; and frustrating. I did finally get it; but it took a bit; most of it relating to the bits and pieces of loading the network drivers piece by piece; sort of old Novell like and early dos / wintel networking stuff.
            - Pete
            Auto mator
              It worked. Captured what looked like to be a network error just before it all died. I restarted it before I left for work this morning recording directly to a text file which I guess I'll forward to Homeseer Tech support when it happens again. As I now know the problem I'll see if I can script a watchdog temporary fix to keep things running.
              Thanks for your help.
                Great news Phill!
                - Pete
                Auto mator
                  Rich has confirmed this is a problem and will be fixed in the next release.
