Gmail error, first time setup
    Troller Zee, trying to send an email during an event. I have read all documentation, and there is no step by step procedure for a newbie to perform this easy task.
    I installed an Everspring Water Sensor, the sensor triggers my setup event into Alarm state or 255 change, but I get an email error in the log. Here it is:
    Jan-18 10:13:03 AM Z-Wave Device: Basment Furnace Water Alarm Status set to NO ALARM (0)
    Jan-18 10:12:54 AM Warning Sending email failed with an irrecoverable error - mail not sent.
    Jan-18 10:12:54 AM Error Exception creating email for sending (To:myaddress@gmail.com, cc:, bcc:, Sub:Home Automation Alert, Attach = An exception was thrown by the type initializer for {0x2}  
    I have set up my gmail name & password in Setup, I have checked the Gmail Box, In the event setup I also entered the To Email, but I have no instructions concerning the From Email, I tried it with & without my email, makes no difference.
    Can anyone help me with direction from here Please ?
    Here's a thread on this same topic:
    http://board.homeseer.com/showthread.php?t=162420
    -Rupp
      tvlarry's issue is "An exception was thrown by the type initializer for {0x2}  "
      The link issue is " '@' is not a valid email address.Parameter name: address"
      This is a Gmail specific issue. The fix for the referenced thread was "Leave the 'From' address under Setup blank."
      With Gmail the "'From' address under Setup blank." is greyed out.
      ~Bill
        Also in the log:
        ~Bill
          Good eye. First ensure you are running the latest HS version for the Zee (released 1/18/14) I would ten check Bugzilla and if the issue hasn't been listed add a new ticket on this issue.
          -Rupp
            Current version is: HS3 Zee Edition 3.0.0.54 No updates available.
            removed gmail address in setup, same issue
            what should be in the from address in the event window ?
            there is horrible lack of instructions for this model for simple procedures.
            thank you all
              ok I have the download, looks like 2 folders, now I do not know how to load the new file in HomeSeer. I did a backup, but I do not know how to manually load a downloaded file into this program.
                whoa - dont use that release Rupp linked to - that is for the Linux version of HS, thats not the right version for the Zee.
                Your email error is actually on the event that you have setup. You have info missing in your event that throws that error.
                79 Z-Wave Nodes, 131 Events, 383 Devices
                Z-Wave, UPB, WiFi
                Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
                  Sorry about that. I'll remove the link to remove confusion. For the Zee updates go into setup and check for updates.
                  -Rupp
                    My selection for the event was very easy:
                    If "this device had its value range of" "255 to 255" ( I also tried "Alarm" )
                    Then "send an email" to: myemail@gmail.com
                    is this not the correct event setup ?
                      I also tried other actions in the event like
                      If "this devices changes & becomes" " ALARM"
                        Try deleting that event completely and creating a new event. Make sure the email address doesnt have any spaces or anything in the 'to' address..
                        Z-Wave, UPB, WiFi
                          Can not leave the TO EMAIL Field blank / here is the error
                          Jan-18 9:43:27 PM Warning Sending email failed with an irrecoverable error - mail not sent.
                          Jan-18 9:43:27 PM Warning None of the email addresses appear to be valid for message 'Home Automation Alert' - check your eMail message settings in HomeSeer.
                          Jan-18 9:43:27 PM Event Event Trigger "Water Sensors Furnace Area Leak Detect"
                          Jan-18 9:43:27 PM Z-Wave Device: Basment Furnace Water Alarm Status set to NO ALARM (0)
                          Jan-18 9:43:26 PM Warning Sending email failed with an irrecoverable error - mail not sent.
                          Jan-18 9:43:26 PM Warning None of the email addresses appear to be valid for message 'Home Automation Alert' - check your eMail message settings in HomeSeer.
                          Jan-18 9:43:26 PM Event Event Water Sensors Furnace Area Leak Detect, Action of Send an Email could not be carried out because its configuration is not complete.
                          Jan-18 9:43:26 PM Event Event Trigger "Water Sensors Furnace Area Leak Detect"
                          Jan-18 9:43:26 PM Z-Wave Device: Basment Furnace Water Alarm Status set to IN ALARM (255)
                            Also, fyi, I tried a different email account under AOL, changed the settings under Setup to the AOL send settings & port, tried to send a text under event email settings to an AT&T phone number, same issue, then tried to send to my AOL email under event, all the same error message, every single time, so I don't think its a gmail setting issue.
                            I have no idea other than this Troller is not working to set up an email alert.
                            Still need your help people, I am lost.
                              ISSUE RESOLVED !
                              Went into system menu & performed a soft reset-reboot, then got this message:
                              Jan-19 9:47:06 AM Error Exception sending email via GMail (To:myemail@gmail.com, cc:, bcc:, Sub:Home Automation Alert, Attach = 5.7.8 Username and Password not accepted. Learn more at5.7.8 http://support.google.com/mail/bin/a...y?answer=14257
                              Turns out that after the reboot, HomeSeer software corrupted my gmail password, I saw something was wrong with the length of the character string, it was too long, so I re-entered the password, and it worked.
                              Thank you all for your suggestions.
