HomeTroller Zee Stability Issues
    Hello,
    My home zee frequently requires a reboot after entering and exiting the edit mode in device status page. Anyone else having the same issue?
    This happens when I use either firefox or ie...
    I've not seen that happen on mine - have you tried chrome?
    79 Z-Wave Nodes, 131 Events, 383 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      I just see it slow down (unresponsive) using Firefox.
      I exit and come back a minute or two later and it is fine.
      I have not needed to reboot.
      @lumen - how are you rebooting the Zee? (what do you do to reboot?)
      - Pete
      Auto mator
      Fanless Intel® Celeron N3160 SoC 8Gb
        Once the unit goes unresponsive the website hangs up indefinitely. I used to just pull the power on it, now I ssh in and type in reboot.
        Should I be doing it differently? I noticed that when i do that the unit does not retain all correct previous statuses of the sensors. What I mean is that if everything was say in a closed state, after the reboot, it would show some things as open.
          I had that with previous version of Zee (now keeping finger crossed with 3.0.0.69)
            .70 is available
            Learn About HomeSeer
              I check to see if the Homeseer Mono Process is running. If it is and its been a while that I requested a shut down then I just kill the mono process.
              I just went to update and noticed a "name resolution" error box came up. Never saw that before. That said updating fine to V.70.
              Current Date/Time: 3/26/2014 6:55:37 PM CDT
              HomeSeer Version: HS3 Zee Edition 3.0.0.70 (Linux)
              - Pete
              Auto mator
                hs3 process
                so on the zee... can I just kill the mono process instead of having to reboot the whole thing?
                ps -ef
                to list it
                and then kill xxxx
                  ps -ef
                  to list it
                  and then kill xxxx
                  Yes - that will stop HS3
                  Z-Wave, UPB, WiFi
                    how do I start it back up?
                    How do I start up the process again? My zee is really acting badly and has become sort of unreliable.. I think I might re-image it.
                      A reboot should start it up.
                      You can just do a "mono homeseer.exe" if you want to start it manually or type "go" in the homeseer directory.
                      - Pete
                      Auto mator
                        Once Zee is up and running generally reliability is good. For example I just had Zee running for over 28 days no problem.
                        However
                        I do have problems with reboots. It seems very common to me that the Zee for no apparent reason sometimes is unlikely to return from a reboot. The lights flash but there's no response to a ping. I'm running headless and so can't see whats on the screen. This has been happening from new. I fix it by re-imaging from an earlier backup but normally end up loosing something or other. I normally use the restart function built into HS but maybe I'll try using putty and shutting down that way and see if it makes a difference to restart reliability.
                        Any advice appreciated.
                        Phill
                          I've seen mine reboot after an update, but it never fully comes back up. I have to pull the power cord to get a good reboot.
                          Z-Wave, UPB, WiFi
                            I've been looking (indirectly) at one users update to V.70. It appears to have removed HSTouch. Not sure really what happened there. A restoral of a previous version; then an update keeps removing HSTouch.
                            User is connecting via satellite; thinking it might be some sort of time out related to latency when restarting HS?
                            I know its doing that dynamic DNS stuff in the beginning (whether or not you utilize the Homeseer Dynamic DNS service).
                            Here the update to V.70 worked fine for me. My set up is "lite" as I been turning on and off the included plugins and not really adding many variables.
                            Historically if I do not pay attention when I shut Homeseer down; and not check for a running Mono process (well to kill it) then it loads a second instance of Homeseer using one port above running one (IE: if its running on port 80, then second instance is on port 81).
                            I am also occasionally taking out the SD card and checking it with GParted on my Ubuntu PC. (and doing an image backup).
                            Looked at whatever was being saved in the logs and noticed this from March 26, 2014. I am going to run a quickie check today with Gparted.
                            Mar 26 18:51:27 ICS-HS3-Zee kernel: [ 8.173640] usb 1-1.2: cp210x converter now attached to ttyUSB0
                            Mar 26 18:51:27 ICS-HS3-Zee kernel: [ 11.775149] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                            Mar 26 18:51:27 ICS-HS3-Zee kernel: [ 12.506228] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                            Mar 26 18:51:27 ICS-HS3-Zee kernel: [ 14.042471] i2c /dev entries driver
                            Mar 26 18:51:27 ICS-HS3-Zee kernel: [ 19.033141] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
                            Mar 26 18:51:27 ICS-HS3-Zee kernel: [ 22.393400] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
                            Mar 26 18:51:27 ICS-HS3-Zee kernel: [ 23.959090] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
                            Mar 26 18:51:28 ICS-HS3-Zee kernel: [ 27.745792] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
                            Mar 26 18:52:27 ICS-HS3-Zee kernel: [ 68.343896] ip_tables: (C) 2000-2006 Netfilter Core Team
                            - Pete
                            Auto mator
