Question
    Question
    I have been running Homeseer on a PC (XP Pro) since it came out upgrading as new releases come out. I only run HS on the PC, but I am getting tired of dealing with virus software, windows updates, performance degrading as the HS uptime increases.
    My devices are X10 and Zwave. I want to still control my media that's on a server, and loose as little functionality as possible. Is the "Zee" a good solution?
    Thanks!
    As of today, the Zee will handle X10, Z-Wave and Insteon. There is no music or media player plugin for it at this time. A future Zee unit is rumored to support more plugins.
    79 Z-Wave Nodes, 131 Events, 383 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      I missed the Insteon announcement relating to the Zee. Where is it?
      - Pete
      Auto mator
      Fanless Intel® Celeron N3160 SoC 8Gb
        I have been reading that plugins are coming, any idea when?
        If I but the Zee now will I be able to upgrade when it supports plugins?
          Do not count on plugins.
          It is a basic controller hence the low price for software and hardware.
          If you want a real controller get a HomeTroller.
          ~Bill
            Got it.
              Re: Question
              It was silently released with v3.0.0.83
              Sent from my SCH-R970X using Tapatalk
              Z-Wave, UPB, WiFi
                So I am guessing that I have to edit the update.hs file or just manually do a get eh?
                root@ICS-HS3-Zee:/usr/local/HomeSeer# ./updatehs.sh 80
                --2014-04-29 07:48:26--  http://<b>http://homeseer.com/update..._80.tar.gz</b>
                Resolving homeseer.com (homeseer.com)... 67.217.100.101
                Connecting to homeseer.com (homeseer.com)|67.217.100.101|:80... connected.
                HTTP request sent, awaiting response... 200 OK
                Length: 18063360 (17M) [application/x-gzip]
                Saving to: `hslinux_zee_3_0_0_80.tar.gz'
                100%[======================================>] 18,063,360  3.41M/s   in 5.5s
                2014-04-29 07:48:32 (3.12 MB/s) - `hslinux_zee_3_0_0_80.tar.gz' saved [18063360/ 18063360]
                - Pete
                Auto mator
                  Edited the updatehs.sh ....
                  sudo rm hslinux_zee_3_0_0_$1.tar.gz
                  sudo wget http://homeseer.com/updates3/hslinux..._0_0_83.tar.gz
                  sudo tar xvf hslinux_zee_3_0_0_83.tar.gz
                  Why the change in methodology? (PITA)
                  Just replace the version number with "83".
                  Updated; neato stuff here!
                  Thinking out loud a bit.....now if the base Zee could talk UPB that would be a feat!
                  I have tested the UPB plugin running on the Zee with the Zee running base HS3 and it does work just fine...
                  - Pete
                  Auto mator
