What is the current release Zee build? My Zee is at 3.0.0.71 and when I hit the update button it doesn't update. I was going to force an update to 3.0.0.83, but that looks like it's still in beta testing and since I'm new to HS I'm thinking that might not be a great idea.
Current Released Zee Build
I would wait a bit for an official release. I have ~22 zwave nodes but cant seem to pinpoint this increased load average.
When you do decide to upgrade, you might consider pulling the SD card out and imaging the card prior to the upgrade. It only takes a few minutes to completely image the Zee and restore it if something goes wrong.HS4Pro on a Raspberry Pi4
54 Z-Wave Nodes / 21 Zigbee Devices / 108 Events / 767 Devices
Plugins: Z-Wave / Zigbee Plus / EasyTrigger / AK Weather / OMNI
HSTouch Clients: 1 Android
Yup here noticed a second update of around 35 patches/updates to the original Wheezy base OS occurred last night. Took a while to update as I was running the updates while HS3 was running.
The Zee will need to be rebooted though as there were some basic updates to the wheezy kernel (bunch of security stuff).
That said still base lining HS with only your script / event running and nothing much else.
I am also using a 16Gb SD card with some over 5 Gb of data now on it.
Current Date/Time: 5/6/2014 7:21:59 AM CDT
HomeSeer Version: HS3 Zee Edition 3.0.0.83 (Linux)
HomeSeer: Is Registered
System Uptime: 6 Days 23 Hours 20 Minutes 22 Seconds
Number of Devices: 7
Number of Events: 6
Event Last Ran: Zee CPU : ZEECPU, Ran at 5/6/2014 7:12:19 AM
Number of unique event scripts used: 2
Modules/Threads: 68 Modules, 0 Threads
HomeSeer Memory Used: 32 MbytesMay-06 7:12:19 AM ZeeCPU 5/6/2014 7:12:19 AM,CPU Load 0.27
May-06 7:02:19 AM ZeeCPU 5/6/2014 7:02:19 AM,CPU Load 0.24
May-06 6:52:19 AM ZeeCPU 5/6/2014 6:52:19 AM,CPU Load 0.31
May-06 6:42:19 AM ZeeCPU 5/6/2014 6:42:19 AM,CPU Load 0.37
May-06 6:32:19 AM ZeeCPU 5/6/2014 6:32:19 AM,CPU Load 0.40
May-06 6:22:19 AM ZeeCPU 5/6/2014 6:22:19 AM,CPU Load 0.26
May-06 6:12:19 AM ZeeCPU 5/6/2014 6:12:19 AM,CPU Load 0.29
May-06 6:02:19 AM ZeeCPU 5/6/2014 6:02:19 AM,CPU Load 0.21
May-06 5:52:19 AM ZeeCPU 5/6/2014 5:52:19 AM,CPU Load 0.29
May-06 5:42:19 AM ZeeCPU 5/6/2014 5:42:19 AM,CPU Load 0.26
May-06 5:32:19 AM ZeeCPU 5/6/2014 5:32:19 AM,CPU Load 0.20
May-06 5:22:19 AM ZeeCPU 5/6/2014 5:22:19 AM,CPU Load 0.29
May-06 5:12:19 AM ZeeCPU 5/6/2014 5:12:19 AM,CPU Load 0.25- Pete
Auto matorHomeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb
HS4 Pro - Ubuntu 22.04 / Lenova Tiny M900 / 32Gb Ram
HSTouch on Intel tabletop tablets (Jogglers) - Asus AIO - Windows 11X10, UPB, Zigbee, ZWave and Wifi MQTT automation-Tasmota-Espurna. OmniPro 2, Russound zoned audio, Alexa, Cheaper RFID, W800 and Home Assistant
Originally posted by rmasonjr View PostI would wait a bit for an official release. I have ~22 zwave nodes but cant seem to pinpoint this increased load average.
