Disk is Full
    Disk is Full
    After receiving a new Zee with my original SD card (and original configuration files), I'm now getting endless "disk full" error messages - such as...
    Warning Could not write to INI file /usr/local/HomeSeer/Config/settings.ini: Disk full. Path /usr/local/HomeSeer/Config/settings.ini
    Z-Wave Error SQL Exception updating Z-Wave data record in the database: database or disk is full{0xA}database or disk is full, Code=13, Link=
    Disk usage reports...
    running comand df -H
    Filesystem Size Used Avail Use% Mounted on
    rootfs 3.9G 3.9G 0 100% /
    /dev/root 3.9G 3.9G 0 100% /
    devtmpfs 222M 0 222M 0% /dev
    tmpfs 46M 218k 46M 1% /run
    tmpfs 5.3M 0 5.3M 0% /run/lock
    tmpfs 92M 4.1k 92M 1% /run/shm
    /dev/mmcblk0p1 59M 20M 40M 33% /boot
    tmpfs 230M 213k 230M 1% /tmp
    tmpfs 230M 99k 230M 1% /var/log
    tmpfs 230M 0 230M 0% /var/tmp
    Any ideas where/how to look for "big" files that don't belong?
    Here I am over the 4 original Gb's into 5 Gb of a 16Gb SD card.
    I went looking and did see some stuff in the root directory. 670.93 MB
    Try this and see what you find.
    find {/path/to/directory} -type f -size +{file-size-in-kb}k -exec ls -lh {} \; | awk '{ print $8 ": " $5 }'
    find / -type f -size + 50000 k -exec ls -lh {} \; | awk '{ print $8 ": " $5 }'
    - Pete
    Auto mator
      Check your energy.hsd file in the Data folder. I'm curious what size it is.
      Sent from my Xoom using Tapatalk 4
      HS4Pro on a Raspberry Pi4
      54 Z-Wave Nodes / 21 Zigbee Devices / 108 Events / 767 Devices
      Plugins: Z-Wave / Zigbee Plus / EasyTrigger / AK Weather / OMNI
      HSTouch Clients: 1 Android
        Thanks for the ideas, but.... Due to a Unix oopsie on my part, I now find myself with an erased disk and get to reflash from HomeSeer's baseline image
