X10 Configuration
    X10 Configuration
    Just got the Zee up and running with the Z-Stick and now want to configure it for X10. I see there is a procedure for configuring dual interfaces on this board.
    I currently use the SmartHome PowerLinc USB interface under HS2, but I don't see a plugin on the Zee (are there plans for one?) available. I still have working CM11A and CM15A units and looks like these (at least the CM11A for now) are supported. Since the CM11A is my best bet now, what do you all recommend I use for a serial-USB adapter. Also, does it matter which USB port it needs to be on the Zee?
    I just tested with a well made USB to Serial device using an FTDI chip set.
    http://www.ftdichip.com/Products/Cables/USBRS232.htm
    That said here tested the CM11A to work fine.
    I also have a few TW-523's online today.
    My X-10 PIM preferences though relate to legacy/new "Volpie" X10 stuff that is levels above the CM11A and TW-523. (X-10 on Steroids)
    (this is only my opinion)
    - Pete
    Auto mator
    Fanless IntelĀ® Celeron N3160 SoC 8Gb
      Rich is working on adding CM15a support to the Zee too. Testing is in progress.
      Learn About HomeSeer
        X10 Configuration
        Thanks guys. Much appreciated. It's good to have options
          CM15A support already here?
          Just received an email from your shop listing sale items. The CM15A is shown (see screen grab) as _now_ being supported by the Zee. Will this work with the current release (HS3 Zee Edition 3.0.0.97) I have installed?
          Crossing fingers and toes
            Hi, you need to upgrade the zee to the latest release. See posting here: http://board.homeseer.com/showthread.php?t=168395.
            Cheers
            Al
              CM15A Support
              Thanks Sparkman. Missed that post. I guess crossing the fingers worked
