Thermostats and HomeTroller Zee
    The HomeTroller Zee looks like a great device and exactly what I am after to get into home automation. The inclusion of HSTouch really sold me on using HomeSeer. Purchasing HS3Pro was just a little out of my price range and it is great to see HomeSeer including HSTouch at such a good price.
    My question relates to thermostats. I intend to purchase three new z-wave thermostats and I want them to be as compatible as possible for easy setup. Can anyone recommend a good thermostat. I have a hot water baseboard setup on the basement and main floor and a hot water in floor heating on the second floor.
    Given I live in Edmonton and gets to -40C in winter I think intelligent thermostat settings could save me quite a bit of money.
    Normally I am not one to bump but struggling to find info on what thermostats are compatible or even what thermostat was used in the demo video.
    Can anyone help or should I contact homeseer support?
      I have 2 Wayne Dalton zwave thermostats and they work OK with the zee. The z-wave thermostats that hs sells should all be compatible.
      I love Edmonton. I spent almost a month there for work many years ago. Flattest place I've ever seen.
      Sent from my Xoom using Tapatalk 4
      72 Z-Wave Nodes, 111 Events, 422 Devices
      Z-Wave, UPB, WiFi
      Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
        Agreed, any of the z-wave thermostats should work. If you're planning to buy them from HST, then I would call them or contact them through this form as well and ask for advice.
        Cheers
        Al
        HS 4.2.8.0: 2134 Devices 1252 Events
        Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
          Thanks for the feedback.
          Tried to find Wayne Dalton thermostats but no luck.
          Contact HomeSeer support as I plan to purchase through them. Will post back with there response. I figured out the one they used in the video was a 2GIG, unfortunately that requires direct beam so probably not the best suited for my needs.
            Did you put in a help desk request for support or did you use a different email link?
            -Rupp
              I went to the homeseer store and clicked contact us and clicked pre-sales inquiry.
              I think I solved my problem. Dug around the HomeSeer and looked at kits/combos. They offered a thermostat combo with Hometroller Z which includes selection of thermostats. There are 5 thermostats to choose from. Gives me a good idea on compatibility and a good discount for ordering as a combo.
              http://store.homeseer.com/store/KitsCombos-C3.aspx
