ZEE speaker clients
    ZEE speaker clients
    How do you add speaker clients to the HomeTroolerZEE. Found the network port box under Tools, setup, and network with a default of 10401. I entered LAN IP address for the WFTT07 but so far..no cigar.
    You actually dont need to do anything on the server side. Just point your WFTT07 to your HS server. Any 'speak' actions on the HS server will be sent to the client.
    79 Z-Wave Nodes, 131 Events, 383 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      rmasonjr...thanks for reply.
      How do you point the WFTT07 to the HomeTrollerZee. They are both connected to my router. I have forwarded the zee's ip address to a port for outside my LAN connections.
        On the WFTT07, launch HSTouch if not already running.
        Select the settings - probably located on the bottom-right.
        Select an empty Server slot - like Server 1.
        Enter the IP Address for your HS Server.
        Enter the username/password (usually default/default).
        Leave the port as 10200.
        Stop/restart the HSTouch client.
        You should be connected at that point.
        Z-Wave, UPB, WiFi
          It's working....
          Works great.
          Thanks rmasonjr..
            Changing Voices
            I have all kinds of voices that I had for HS2 pro. Can those go on HomeTroller Zee. Would love to get rid of that awful voice.
            danielbo
              No the Zee uses the Flite TTS Engine. Rob answered this same question earlier about a voice here:
              http://board.homeseer.com/showthread...38#post1137238
              -Rupp
