wi-fi adapter
    wi-fi adapter
    I'm new to the HomeTroller Zee and trying to get it to work with the Wi-Fi adapter to enroll a battery powered door lock not physically located within 3 feet of the HomeTroller. I cannot get the adapter to work in the Wi-Fi mode. It seems to only work with the Ethernet cable connected. I have followed the Homeseer instructions and have gotten the adapter to produce an IP address using the Find command. When I try to use the Wi-Fi IP address, I only get a "this page cannot be displayed response".
    Has anyone been successful at enrolling a battery powered device using the Wi-Fi adapter? I already have the door lock installed and it is going to be a problem to try and get the HomeTroller to the device with an Ethernet cable attached.
    Haven't used WiFi with my Zee. I made a CAT-5 cable long enough to reach everywhere in my house. Alternatively, you could bring the door lock to the Zee instead of the other way around.
