I was testing the pump house heaters earlier and plugged the Ethernet over Power Line unit in at the house and the second in the pump house. Didn't show a connection. I tried it at an outlet by the pond on the same circuit and did get connected. It is possible I could move it to a different outlet in the pump house and get a connection. I had to do that in the garage. Suspect that there may be some sort of interference.
I'll get the Pi and Z-wave working in the garage, then come back to the barn. Since I do have the wires out there (in conduit), I'd like to figure out how to extend the signal. But what I'm doing will work for now.
Getting a line to the pump house will require a cable plow or a backhoe. If I can't get the power line option to work, I might look at a WiFi solution. But again, that is down the road.
Barry
Barry
