Zee & Foscam Fi9821W
    I purchased a Zee with a Foscam Fi8918W camera, WFTT07. I had wall switches and modules, etc., from an ADT Pulse system. All went well and is up and running.
    I then added four Fi9821W cameras to the system. From there it went all downhill. Zee can find and see all 5 cameras. But I can only view the 8918W (back office) camera. If I look at any other camera first all I get is the pan and tilt controls, that don't work. If I look at the 8918W (back office) camera first I can see and control it. From that one to any other camera and I get a still shot of the 8918W (back office) camera and no control over that one or any other. I have changed the log-ins and passwords. All five have a different port forwarding address. All have different IP addresses assigned to them.
    Any suggestions or help would be appreciated since now I have a system that is not working for what I need it to do.
    Typical
    Wanted to thank everyone here for the support. Just like I got from HomeSeer itself. NONE.
    IF anyone reads this that might be interested in HomeSeer, run away. Or you can buy mine cheap since there is no support after the sale.
      Sorry, for what its worth, I cant see my cams via HSTouch either. I havent gotten back to it since other priorities came up. All I can recommend is to make sure your HSTouch server plugin *and* the HSTouch client are at the very latest releases.
      79 Z-Wave Nodes, 131 Events, 383 Devices
      Z-Wave, UPB, WiFi
      Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
        I hope you tried the HomeSeer Help Desk. They are very responsive and will do everything in their power to resolve your problem. This forum is a great resource for a wealth of helpful information but is not the official HomeSeer location to resolve system problems. Please give the Help Desk a try if you have not contacted them.
        Bob
          @Jack,
          Do not get discouraged. As Bob states above, give the help desk a call.
          I am currently running here with one HSTouch 3 client / server and its doing fine.
          HSTouch Server Version 3.0.0.59 on HS3 Pro Edition 3.0.0.149 (Linux)
          - Pete
          Auto mator
          Fanless IntelĀ® Celeron N3160 SoC 8Gb
            Working with cameras in HSTouch is difficult. Every brand of camera has a different control string. You need to figure out the exact http commands to send to the camera. And you may need to send a username an password to the camera before it will do anything. Try controlling the camera via your web browser. This will help you figure out the syntax needed in HSTouch Designer. Also, make sure the " is video" setting for the image window is set to TRUE. I'm not very good designing HSTouch pages, but by being persistent, I am able to get most things working.
            Steve Q
            Sent from my iPad using Tapatalk HD
              Or, you might try using our actual support channels. You can 603-471-2816 or you can submit a helpdesk ticket.
              Learn About HomeSeer
                Actually I did call. Can't remember who I talked with, but it was within the first 3 months that I had HomeSeer installed. I was told that as long as I did NOT purchase the cameras from HomeSeer they would not support them. So that told me that HomeSeer would only support the equipment sold via their website and therefore I am on my own. So I came here for any help I could get.
                  I'm guessing you misunderstood. Support for the newer HD Foscam cameras was only added last month. HSTouch did not work with these cameras prior to that.
                    Can the hs zee actually support more than one camera. In speaking with someone at hs sales last year they mentioned the zee would at best be able to handle one camera?
                    Just wondering?
                    Tom
                      Just wondering?
                      At the moment, HSTouch requests a stream of jpg snapshots from the cameras and it takes some time to resolve these images, especially over the internet. That is the bottleneck, more so than any HomeTroller model limitations. The problem is exacerbated when resolving the snapshots from higher res cameras, like the new Foscam ones.
                      Improving camera support is on our development schedule and hopefully we'll get to it this year. However, there is no firm ETA on this.
