Time variable for Zee alarm clock
    Dear HomeSeer Experts,
    I have set up an event on the Zee that starts slowly to increase the light level of my bedroom bedside lamp. I am using this as a natural light alarm clock in the morning.
    Is there a way where I could use a variable to trigger an event on the HomeTroller Zee? I could change this variable by sending a mail to the Zee. But I did not find such a variable for a specific time without a date, e.g. 7:30 am.
    Please advice.
    Best regards,
    Alex
    Create a manual event with the wait command set light 15% wait 15 seconds set light 20% etc. Then call that event as a second event at the time you want it to go off.
    Using a light alarm is a great idea - I like the idea of gradually adding lux.
      Thank you. Great idea.
      But how would you call the event at a specific time that I can change without to change the event code?
        In the first event, it is a manually triggered with no time set to start. You just use the wait command to create the gradually increasing luminance.
        Then you create an event for the time, which calls that original event. Rhe original event has only relative time (through wait) and not an absolute time, so there is no need to modify the code.
          Using the wait command inside the first event is clear. A great idea and I will use it.
          What I still miss is how I initiate the 2nd event at a specific time that I can easily change. So that at the evening I decide to start the event at 7 am next morning but the following day I decide to start the event at 8 am in the morning.
          I can set the event to start every day at 7 am. This is clear and works fine. But if I want to adjust this to lets say 8 am spontaneously I have to open the event and change the time manually to 8 am.
          My question is if there is a way I could use a "wake up" variable that I can set e.g. by email or by the UI. I could than adjust the wake up time for the next day easily
          Would be great if you could help.
          I appreciate the support!
            Yes there is no easy way to set time of the event thru out-of-the-box HS Touch UI on android/iOS. One has to use web interface which is not very useful for most folks in your household. I really hope HS folks will wake up one day and give us virtual alarm clock that works out of the box with HS Touch.
            For now I did this:
            http://board.homeseer.com/showthread.php?t=157454
            It requires few steps but you can setup as many clocks as you want and use stock HS Touch to set the time.
              Excellent :-) Thank you.
              Unfortunately it is not working on the Zee.
              The event is called:
              Running script in background: /usr/local/HomeSeer/scripts/wake_up_zora.vb("Main","A20,Wake up everyone event,15,Wake up everyone event early")
              But than it shows a error 3:
              Running script /usr/local/HomeSeer/scripts/wake_up_zora.vb :Exception has been thrown by the target of an invocation.->Does entry point Main exist in script? at System.Reflection.MonoMethod.Invoke (System.Object obj, BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00000] in :0 at System.Reflection.MethodBase.Invoke (System.Object obj, System.Object[] parameters) [0x00000] in :0 at A.c17b105f989efe61e5979e67bec1ef734.cffd66cb0782c50126727e3f a75582d7a () [0x00000] in :0
                Hmm seems like you didn't copy entire script for some reason - does it have this at the top of the file:
                Sub Main(ByVal Parm As Object)
                  Thanks for the quick reply.
                  The script is downloaded and directly uploaded without any modification.
                  Please find attached a screenshot of the Zee event that is calling the script.
                  Is it possible that it requires modifications for the Hometroller Zee due to Linux?
                  Once again, thank you for the help.
                    Try removing the word Main from the sub or fiction field in the event. It will call Main by default so does not need to be entered. I've seen that issue with some of my events before and that's resolved it for me. Not sure why it works most of the time, but not consistently.
                    Cheers
                    Al
                      Thank you very much :-)
                      Still an error message, even different at this time.
                      Running script /usr/local/HomeSeer/scripts/wake_up_zora.vb :Exception has been thrown by the target of an invocation.Cast from 'String' to type 'Integer' is not valid.
                      Any idea what this means?
                      The events before are recorded as:
                      Feb-05 1:22:41 PM Event Running script in background: /usr/local/HomeSeer/scripts/wake_up_zora.vb
                      Feb-05 1:22:41 PM Event Event Trigger "Wake_up_everyone_event_early Wake up everyone set event"
                        Well, that means the script is actually running but failing due to a value not being able to be converted from a string to an integer. Maybe post a screen shot of the Device Value tab of your A20 device that you created.
                        Cheers
                        Al
                          Sorry for the delay.
                          Attached the images as requested.
                            You need to use the Device Reference ID to call the script. In your case that's 14 not A20. Change the parameters in your event that calls the script and replace A20 with 14.
                            Cheers
                            Al
                              Thank you Al.
                              We are getting closer to a solution. The log shows that the wake-up time is set. Great. Thank you :-)
                              Unfortunately it still displays a small error message in the log:
                              Running script /usr/local/HomeSeer/scripts/wake_up_zora.vb :Exception has been thrown by the target of an invocation.Cannot find the requested class member.
                              Attached the screenshots of the log and the event that calls below script that I did copy 1:1 (moved the file) from the great post of Person: http://board.homeseer.com/showthread.php?t=157454
                              Any advise how to avoid the invocation?
                              Best regards and thank you for the help,
                              Alex
                              ' This script expects input in the following format
                              ' "Alarm device ID,Wake up event name,Early event offset in minutes,Early wake up event name"
                              ' E.g.
                              ' wake_up_zora.vb("Main","A20,Wake_up_everyone event,23,Wake_up_everyone event early")
                              ' Early offset in minutes must be less than 720 (12 hours)
                              ' If early offset is set to zero then only wake up event exists. Put zero for offset *and*
                              ' early event.
                              Dim Parameters () As String
                              Dim WakeUpEvent, WakeUpEventEarly As String
                              Dim EarlyOffset, AlarmClockDevice
                              Dim WakeUpTime
                              Dim Minutes, Hours, Minutes2, Hours2
                              Dim MinutesEarly, HoursEarly
                              Dim MessageID As String
                              MessageID = "INFO: WakeUpZora"
                              ' Split input on comma
                              Parameters = Split(Parm.ToString,",")
                              AlarmClockDevice = Parameters(0)
                              WakeUpEvent = Parameters(1)
                              EarlyOffset = Parameters(2)
                              WakeUpEventEarly = Parameters(3)
                              ' Get the time set from the clock device
                              WakeUpTime = hs.DeviceValue(AlarmClockDevice)
                              hs.WriteLog (MessageID, "Wake up time is set to " & WakeUpTime)
                              ' If real wake up time provided (alarm enabled)
                              ' then setup appropriate events
                              If WakeUpTime <= 2359 Then
                              ' Grab hours and minutes from the clock value
                              WakeUpTime = WakeUpTime / 100
                              Hours = Math.Floor(WakeUpTime)
                              Minutes = 100*(WakeUpTime - Math.Floor(WakeUpTime))
                              ' Set WakeUpTime for main event
                              Call SetEventTime (Hours, Minutes, WakeUpEvent, MessageID)
                              ' Error out on offset > 720 (12 hours) and clamp at 1 hours
                              If EarlyOffset < 0 OR EarlyOffset > 720
                              hs.WriteLog (MessageID, "ERROR: Early Offset Out of 0-720 BOUNDS!: " & EarlyOffset)
                              hs.WriteLog (MessageID, "Forcing early offset to 1 hour")
                              EarlyOffset = 60
                              End If
                              ' Calculate hours and minutes to adjust
                              MinutesEarly = (EarlyOffset Mod 60)
                              HoursEarly = (EarlyOffset - MinutesEarly)/60
                              ' Subtract Minutes/Hours Early, adjust if negative
                              Hours2 = Hours - HoursEarly
                              Minutes2 = Minutes - MinutesEarly
                              If Minutes2 < 0 Then
                              Minutes2 = Minutes2 + 60
                              Hours2 = Hours2 - 1
                              End If
                              If Hours2 < 0 Then
                              Hours2 = Hours2 + 24
                              End If
                              ' Adjust and set WakeUpTime for early event
                              If EarlyOffset = 0 Then
                              ' No early event for this clock defined
                              Else
                              Call SetEventTime (Hours2, Minutes2, WakeUpEventEarly, MessageID)
                              End If
                              Else If WakeUpTime = 9999 Then
                              ' Disable events since alarm is turned off
                              hs.WriteLog (MessageID, "Disabling WakeUp Events")
                              hs.DisableEvent(WakeUpEvent)
                              Else
                              hs.DisableEvent(WakeUpEventEarly)
                              End If
                              Else
                              hs.WriteLog (MessageID, "Time set is OUT OF BOUNDS!:" & WakeUpTime)
                              End If
                              End Sub
                              Sub SetEventTime (ByVal Hours As Integer, ByVal Minutes As Integer, ByVal WakeUpEvent As String, ByVal MessageID As String)
                              Dim IRef
                              Dim AM_PM As String
                              Dim FinalWakeUpTime As String
                              ' Detect if we need to use 24 hour or AM/PM time format
                              If Now.ToString.Contains("AM") OR Now.ToString.Contains("PM") Then
                              ' - if <1200 -> this is AM, otherwise PM
                              If Hours < 12 Then
                              AM_PM = "AM"
                              ElseIf Hours <= 23 Then
                              Hours = Hours - 12
                              AM_PM = "PM"
                              Else
                              hs.WriteLog (MessageID, "Hours set if OUT OF BOUNDS!: " & Hours)
                              End If
                              ' When time is 00:00 or 12:00 the AM/PM scheme
                              ' requires making it 12AM/12PM so add 12
                              ' if hours < 1
                              If Hours = 0 Then
                              Hours = Hours + 12
                              End If
                              FinalWakeUpTime = String.Concat(Hours, ":", Minutes, " ", AM_PM)
                              Else
                              FinalWakeUpTime = String.Concat(Hours, ":", Minutes)
                              End If
                              hs.EnableEvent(WakeUpEvent)
                              hs.WriteLog (MessageID, "Wake Up Time for " & WakeUpEvent & " event is set to: " & FinalWakeUpTime)
                              IRef = hs.GetEventEx(WakeUpEvent)
                              IRef.ev_time = FinalWakeUpTime
                              End Sub
