Backup system questions
    #16
    Originally posted by rmasonjr View Post
    You are correct. A backup of the configuration in the HS GUI will not save any images you have added - those live under the html\images folder.
    You have a few options:
    --Image the SD card using Win32DiskImager. You should do this anyway to keep a good working image on-hand for disaster/recovery.
    --Use WinSCP to copy the entire /usr/local/HomeSeer folder from your Zee to a folder on your PC, then copy it up to another Zee. Login as root for downloading and uploading.
    --Use my backup script which only backs up the /usr/local/HomeSeer folder. Login as homeseer when running the script. Login as root to restore it.
    http://board.homeseer.com/showpost.p...9&postcount=12
    Iv tried both now, the Win32DiskImager made a 7,88gb image file. While copying the /usr/local/HomeSeer folder from your Zee only was 39,8mb.
    So don't know what is the best. I will test a bit more. But will that small 40mb file actually backup all virtual devices made and events made with images?
    Certified installer for HomeSeer, Control4, KNX and Eaton/xComfort
      #17
      Yes. That backup contains everything in the homeseer folder.
      Sent from my SCH-R970X using Tapatalk
      79 Z-Wave Nodes, 131 Events, 383 Devices
      Z-Wave, UPB, WiFi
      Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
