Anybody please show where to find documentation on scripting syntax, variables and such.
For example: Let's say I want to create an event (or script) to capture the user code that was used to unlock the door in a variable and translate it in a table to come up with the name of the user. I found a way to do the closest thing but it is only possible kind of backwards as in [if this used code is used, do that..]. The problem with this is if you have fifteen user codes, then you need to create fifteen different events.. this beats the purpose of automation and computers.
So far, I was able to figure out only the two variables below:
$$time
$$date
Please publish variables you know of along with their description/definition. Thanks.
a.
$$time
$$date
a.
