Zee update Z-Wave Z-net drivers
    Playing with the Zee most current drivers and noticed that they do not include the HomeSeer Z-Net device.
    The old Z-Troller and Aeon stick worked fine. It would be nicer though to also include the new Z-Net device in the Z-Wave configuration.
    Bugzilla - Bug 2695 - Homeseer Zee doesn't include Z-Net Z-Wave drivers
    - Pete
    Auto mator
    Fanless Intel® Celeron N3160 SoC 8Gb
    We are working on a release, but not really sure why you would add a Z-NET to a Zee?
    Anyway, you can still use the Z-NET, just select "Ethernet" for your interface, enter the IP of your Z-NET and set the port to 2001.
      Thank you Rich.
      Adding Z-Net to a Zee would extend the RF footprint of the Zee.
      Do the current Zee Z-Wave drivers work with Z-Wave Plus?
      Testing here with the RaZberry GPIO interface didn't show any of the Z-Wave plus devices on the current Zee Z-Wave drivers.
      See here.
      I am looking at updating the Zee here to an RPi2 with a new Z-Wave Plus GPIO card rather than utilizing the Aeon stick that originally came with it.
      I can run the Linux HS3 Z-Wave drivers plugin on the Zee right now talking to my HS3 Pro on Linux and it works well with Z-Wave plus.
      Updating the current Zee Z-Wave drivers to using Z-Wave Plus would be beneficial to the Zee stand alone set up. (2nd home et al type of stuff).
      It would also add some longevity to the original Homeseer 3 Zee. (IE: upgrading it to an RPi2 / GPIO Z-Wave plus card). - little steroidal injection of sorts....
      - Pete
      Auto mator
        There is a Beta build available for the Zee, update your zee using SSH to build 162 and you will get the latest Z-Wave plugin that supports Z-Wave+.
        Thank you Rich.
        See here.
          Thank-you Rich.
          Downloaded and running it right now.
          Z-Wave is showing version 3.0.0.216
          Driver shows Lib Version Z-Wave 3.99 / Z-Wave IC ZW050x
          Wow!!!
          Thank-you Rich..Zee Z-Wave optimization is now showing classes and seeing Z-Wave plus stuff.
          Z-Wave manufacturer information for node 2, ID: 5=5H (Intermatic), Type: 3=3H, ID: 3=3H
          Z-Wave manufacturer information for node 3, ID: 5=5H (Intermatic), Type: 2=2H, ID: 3=3H
          Node: 2 Supports Class(es): BASIC, SWITCH_MULTILEVEL, SWITCH_ALL, VERSION_V2, MANUFACTURER_SPECIFIC
          Node 2 is Z-Wave version: Lib: 1.28 App: 1
          Node: 3 Supports Class(es): BASIC, SWITCH_BINARY, SWITCH_ALL, VERSION_V2, MANUFACTURER_SPECIFIC
          Node 3 is Z-Wave version: Lib: 1.28 App: 1
          Instant status is not supported for Intermatic Z-Wave device Node 2 Z-Wave Intermatic Switch Multilevel Node 2 (2), polling is being set to 10 minutes.
          Instant status is not supported for Intermatic Z-Wave device Node 3 Z-Wave Intermatic Switch Binary Node 3 (3), polling is being set to 10 minutes.
          Finished with Z-Wave device synchronization.
          - Pete
          Auto mator
            Closed Bugzilla ticket #2695 changing it to resolved.
            - Pete
            Auto mator
