ZEE, after update, no yhellow network light, no connection - Solved!
    did the ZEE update, di dnot power down, etc; software said it was going back to main page;
    but page did not show up
    went to thhe ZEE, red power is on, but no network light; can't see it on the router;
    tried power down, power up, powered router down, up, etc;
    can't see it
    wanted to work with the IFTTT stuf, it was the only reason I updated the software, now I can't use it at all;
    help please
    thanks
    Can you hook it up to an HDMI monitor/TV and see if it is starting up?
    79 Z-Wave Nodes, 131 Events, 383 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      after multiple router/device p;ower cycling, I got the yellow light. I am able to get to the IP address
      but now I can't log into the IFTTT part;
      I go to the https://myhs.homeseer.com/login?Error=Not+Authenticated. address (minus the error), enter the username and password I had set up, it comes back, blanks out the password, and states "HomeSeer is not running"
      should possibly go as part of my OTHRE post (related to the IFTTT), but if you can help, it is appreciated
      thanks
        I get the same thing here...
        Sent from my Xoom using Tapatalk 4
        Z-Wave, UPB, WiFi
          EUREKA -
          I selected USERNAME, "FORGOT password", got a password reset, logged in with new settings, and it WORKED !
          will experiment more....
