ZEE, updated, not seeing the z-Wave interface, how to refresh?
  • Pete
    any way to bypass this, or use the zEE device ID?
    No
    any other options to log in?
    No
    if you don't mind continuing to try, I don't mind, but if it takes a reset, we can do that too
    Yes; if you feel like that will help you.
    Tiny baby steps now.
    Try creating a new user in HS3 Zee GUI first before a total reset.
    Give the user admin rights and try using that user in SSH. You will need user sudo access in the SSH terminal session.
  • aoz
    tried homeseer, etc
    no luck
    access is denied
    if not, any way to blow the whole thing up, start again; I'd have to rebuild my devices, but for the time I've spent on this, it is nuts.
    I don't mind working with the SSH (software is installed)
    thanks
    nick
  • Bob_Linux_User
    I can't get past LOG IN AS -
    If you haven't already, Try
    Username: homeseer
    Password: hsthsths3
    Bob
  • aoz
    I have tried all permutations of the device (HomeZEEMaster, etc), and items that I recorded as passwords, but all come up as invalid
    I had recorded all these when I set up the device.
    I have these stored in KeePass, and I am trying all combinations of this
  • Pete
    OK
    1 - shut down Homeseer 3 on the Zee (tools / system / SHUTDOWN Homeseer)
    2 - Putty to the IP of the Zee. (configure one SSH terminal session to IP)
    3 - log in with your homeseer user name and password
    4 - type "sudo su" after logging in and show me what you see.
    5 - type your password
    6 - next type in cd /usr/local/HomeSeer
    7 - next type in just ls
    8 - here you will see the entire Homeseer Zee 3 directory
    username@ICS-HomeTrollerZEE:~# cd /usr/local/HomeSeer
    username@ICS-HomeTrollerZEE:/usr/local/HomeSeer# ls
    aotall last_exception.txt
    autostart_hs Logs
    autostart_xaphub.sh Mail.dll
    bin Media
    change_password.sh mochad
    check_passwd Mono.CSharp.dll
    Config password_check.c
    ConfigBackup play_audio.sh
    CSScriptLibrary.dll RecoveryInstall.sh
    Data RecoveryInstall.txt
    Docs register_with_find.sh
    factory.sh restart.sh
    factory.sh.save RssToolkit.dll
    go run_command_raw.sh
    Grammar run_command.sh
    HomeSeerAPI.dll Scheduler.dll
    HomeSeerUtil.dll Scheduler.pdb
    hs3linuxhs3zee.txt scripts
    HSCF.dll shutdown_controller.sh
    HSConsole.exe speak.sh
    HSGraph.dll speak_to_file.sh
    hslinux_zee_3_0_0_149.tar.gz System.Data.SQLite.dll
    hslinux_zee_3_0_0_162.tar.gz temp
    hslinux_zee_3_0_0_80.tar.gz Temp
    hslinux_zee_3_0_0_.tar.gz update_extra.sh
    HSPI_CM15A.dll updatehs.sh
    HSPI_HSInsteon.dll updater.txt
    HSPI_HSTOUCH.dll Updates3
    HSPI_X10.dll update.sh
    HSPI_X10.dll.V36 Wave
    HSPI_ZWave.dll wave_files
    HSPI_ZWave.dll.config xap
    HSZWLib.dll ZWaveAES.dll
    html ZWave_Company.dll
    Insteon.Network.dll
    9 - PAUSE - next we will download new Zee update OS via the command line SSH prompt.
    Personally here I also like to update the RPi OS. Easy to do but it may take an hour or two. You decide what you want and tell me.
    BTW here is what the SSH Applet running on HS3 looks like.
    Attached is the Putty configuration window and the putty session to the Zee. You should see the same.
  • aoz
    OK, I have no idea WHAT I am using (but am computer literate, so do step by step, I understand the concept of what we are doing, but have not used these tools)
    1. have WINDOWS
    2 downloaded PUTTY install package, and WinSCP package
    3. IP is 192.168.0.108
    4. I am viewing my home machine, from office, using TightVNC, but I have control over it; so we can plod through
    I AM HERE right now, none of steps below have been done.
    ZEE is powered on, I have internet explorer viewing it with the SETUP screen
    need clarification on items below
    5 - You have to shut down the HS3 application first.
    6 - figure out how to SSH to the box (personally easier than using a monitor, keyboard and mouse).
    7 - show me an SSH command line prompt on the RPi utilize and do a "uname -a"
    8 - copy and paste that here.
  • Pete
    OK
    BTW if you configure a VPN to your home network and your office allows for VPN you can do all of this via a VPN tunnel to home. You might want to entertain this feature on your home network firewall (say running OpenVPN). You can't do this though via the GUI you see from work unless you install an SSH page / applet to your Homeseer Zee. i think it would maybe work as the SSH session is local to the Zee.
    1 - guessing you are using a windows box on your network
    2 - install Putty and WinSCP on the box
    3 - you need to know the IP of the ZEE
    4 - SSH from your Windows box to the ZEE
    5 - PAUSE here. Post here when you have installed the two said application on your Windows box and have SSH'd to your Hometroller Zee.
    If you are using windows then download Putty / WinSCP to your windows box first.
    Putty can be found here.
    WinSCP can be found here.
    If you utilize Linux desktops then disregard the above.
    Here is what I see SSHing and logging in to my Hometroller Zee. Do a clip and paste from your Hometroller Zee when you get there.
    Linux ICS-HomeTrollerZEE 3.18.7+ #755 PREEMPT Thu Feb 12 17:14:31 GMT 2015 armv6l
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    username@ICS-HomeTrollerZEE:~# uname -a
    Linux ICS-HomeTrollerZEE 3.18.7+ #755 PREEMPT Thu Feb 12 17:14:31 GMT 2015 armv6l GNU/Linux
  • aoz
    I havde button but nothing shows up, when I hit it.
    see attached
    I am not familiar with the SSH, but am willing to try.
    I am currently at my office, can't do much on the home system (trying to fit it inbetween office stuff)
    so, give me next directions, and if I don't get ot theim this morning, I will will work with it after 2 pm
    nick
  • Pete
    DISABLE ALL the plugins first; baby steps here.
    Go to Tools / General / Setup and push the check for updates button as shown in the picture above.
    The update is more than a minute long. Be patient as it will update HS3 slowly on the RPi. Go meandering in your home and do not watch the clock.
    If you do not have that button we will need to try it via an SSH session. You want to stick with HS3 Zee release versions of the HS3 software for the time being.
    I do not recall if the update button was there on Version .152 of the Zee at this time.
    Are you familiar with remoting to the Zee via SSH?
    If not familiar with SSH remote of the Zee and you have a monitor / keyboard / mouse connection to the Zee we can just do it via a terminal session manually.
    Do that first and show me a picture of the updated Zee HS3 OS. You can just do a clip of text and paste here.
    Current Date/Time: 4/10/2015 7:48:24 AM CDT
    HomeSeer Version: HS3 ZEE Edition 3.0.0.162 (Linux)
    HomeSeer: Is Registered
    Z-Wave configuration is a 3 step thing. (we will get to that part in a little bit).
  • aoz
    HOW do I update this? I can't find any options to do ANYTHING with the zwave stick, etc;
    PLUGINS do not show me anything able to be done for zwave....
  • Pete
    @Nick
    Rich has updated the Zee new Z-Wave driver to be able to utilize the new Homeseer Z-Net device.
    Here is a picture of the current Homeseer Zee using most current Z-wave drivers.
    Personally I would update the Homeseer Zee OS first with V.162 and then update the Z-Wave Zee drivers.
    The current Z-Wave driver V 3.0.0.216 will work fine with the Z-Wave Aeon stick (I tried it and it was fine).
    You are currently utilizing V 3.0.0.190. Most current version is 3.0.0.216. Most current Z-Wave 216 driver will not work with the older Zee HS3 OS.
    BTW in order to run the most current Z-Wave Zee version you have to also be running most current Zee - HS3 - Lite OS which is V.162.
    Baby steps here. Disable all of the plugins first. Update the Zee HS3 OS to V.162. Then update the plugins.
    1 - Disable all plugins first on the Zee
    2 - Update the Zee to most current Zee OS shown on update page
    3 - Restart Zee
    4 - Update Plugins on Zee (well specifically Z-Wave Plugin).
  • rmasonjr
    When you enable the plugin, there should be log entries. Try disabling the plugin, then re-enable it, then check the logs.
    Sent from my SCH-R970X using Tapatalk
  • aoz
    HELP, anybody.... very frustrating, can't use the ZEE or ZStick
    any help with this?
    I've posted a helpdesk ticket this morning -
    have been fooling with this for over two days.
    this is nuts, all I did was try to update....
    thanks
    nick
  • aoz
    here is part of the log....
    not sure how to decipher
  • aoz
    I'm getting no place to LOAD the plugin.
    the log does not show an error...
    the PLUGINS button does not show zwave as an option....
