About a week ago the hstouch on my zee updated and since then I have been having multiple issues. First my front door lock kwikset 910 stopped communicating, then my thermostat CT1000, then the light switch closest to the thermostat.
I tried to fix, rescaned finally I excluded restarted everything and included the node but they just don't communicate properly. I have my zee right next to the thermostat the floor right above the front door. and I just can't make any progress.
Suggestions?
Device synchronization needs to create devices for 5 new nodes.
Node: 4 Supports Class(es): MANUFACTURER_SPECIFIC_V2, VERSION_V2, SECURITY
Node: 4 Supports Secure Class(es): MANUFACTURER_SPECIFIC_V2, VERSION_V2, SECURITY, BATTERY, ASSOCIATION, CONFIGURATION_V2, PROTECTION, DOOR_LOCK_V2, USER_CODE, SCHEDULE_ENTRY_LOCK_V3, DOOR_LOCK_LOGGING, ALARM, TIME_PARAMETERS, BASIC
Node 4 is Z-Wave version: Lib: 2.78 App: 1.3
Node: 6 Supports Class(es): MANUFACTURER_SPECIFIC_V2, VERSION_V2, SECURITY
Node: 6 Supports Secure Class(es): MANUFACTURER_SPECIFIC_V2, VERSION_V2, SECURITY, BATTERY, ASSOCIATION, CONFIGURATION_V2, PROTECTION, DOOR_LOCK_V2, USER_CODE, SCHEDULE_ENTRY_LOCK_V3, DOOR_LOCK_LOGGING, ALARM, TIME_PARAMETERS, BASIC
Warning: Node 6 supports the MANUFACTURER_SPECIFIC command class but manufacturer information was not obtained. Cannot continue with this node.[/COLOR][/COLOR]
Node: 11 Supports Class(es): BASIC, CLOCK, INDICATOR, MANUFACTURER_SPECIFIC_V2, SENSOR_MULTILEVEL_V2, THERMOSTAT_MODE_V3, THERMOSTAT_OPERATING_STATE_V2, THERMOSTAT_FAN_MODE_V3, THERMOSTAT_FAN_STATE, THERMOSTAT_SETPOINT, VERSION_V2, CONFIGURATION_V2, BATTERY, ASSOCIATION, MULTI_INSTANCE
Warning: Node 11 supports the MANUFACTURER_SPECIFIC command class but manufacturer information was not obtained. Cannot continue with this node.
Node: 14 Supports Class(es): SWITCH_BINARY, SWITCH_ALL, CONFIGURATION_V2, VERSION_V2, MANUFACTURER_SPECIFIC_V2
Node 14 is Z-Wave version: Lib: 3.42 App: 3.1
Node: 15 Supports Class(es): SWITCH_MULTILEVEL_V3, SWITCH_ALL, SCENE_ACTIVATION, SCENE_ACTUATOR_CONF, MANUFACTURER_SPECIFIC_V2, VERSION_V2, MANUFACTURER_PROPRIETARY, NODE_NAMING, POWERLEVEL
Node 15 is Z-Wave version: Lib: 3.52 App: 0.7
Warning: An error (B) was reported attempting to get multi-channel or multi-instance information from node 11
Enabling Lock status for Kwikset device First Z-Wave A Back Door (4)
4 out of 4 Child devices of node 4 were created successfully.
Suggestions?
