I'm trying to get z-wave stick working on the HomeTroller Z. When I press blue button there is no blinking as I thought there should be when adding device to the network. Attached is log from initialization of the Aeon Stick to the attempt to press blue button and add first node device;
I don't understand the message about the TTY port since the device status for the z-wave stick shows as "ok" on the control panel. FYI - Plugged into ttyUSB0, and working, is an X-10 interface.
Could anyone offer a suggestion as to what I'm missing? Thanks in advance.
May-02 1:49:55 PM Plug-In Finished initializing plug-in Z-Wave
May-02 1:49:56 PM Z-Wave Z-Stick: ============================================================ ==========
May-02 1:49:56 PM Z-Wave Z-Stick: ----------------------------------------------------------------------
May-02 1:49:56 PM Z-Wave Initializing Z-Wave interface Z-Stick (Aeon Labs Aeotec Z-Stick) on /dev/ttyUSB1
May-02 1:49:56 PM Z-Wave Z-Stick: Getting node information from controller...
May-02 1:49:58 PM Z-Wave Z-Stick: Controller Manufacturer: Aeon Labs, ID=0x1, Type=0x2
May-02 1:49:58 PM Z-Wave Z-Stick: Controller firmware version: 3.7
May-02 1:49:58 PM Z-Wave Z-Stick: Z-Wave Serial API version: 5
May-02 1:49:58 PM Z-Wave Z-Stick: Z-Wave interface node ID: 1, Home ID: 018518CC
May-02 1:49:58 PM Z-Wave Z-Stick: Found 1 Z-Wave nodes in interface node ID 1 (Z-Stick)
May-02 1:49:58 PM Z-Wave Z-Stick: Z-Wave PC Controller Library Version: Z-Wave 2.78 (ZDK 5.02.3 Patch 3)
May-02 1:49:58 PM Z-Wave Z-Stick: Z-Wave PC Controller is Type: Static Controller
May-02 1:50:00 PM Z-Wave ************************************************************ *******************
May-02 1:50:00 PM Z-Wave STARTUP COMPLETE: All configured interfaces were successfully initialized.
May-02 1:50:00 PM Z-Wave Starting Z-Wave Polling for Network 018518CC...
May-02 1:51:25 PM Z-Wave Warning Z-Stick: Exception(1) with COM port (/dev/ttyUSB1): Input/output error
May-02 1:51:25 PM Z-Wave Warning Z-Stick: The serial port (/dev/ttyUSB1) was not found in the system. Will keep waiting for it...
May-02 1:51:26 PM Z-Wave Z-Stick: Getting node information from controller...
May-02 1:51:27 PM Z-Wave Z-Stick: Controller Manufacturer: Aeon Labs, ID=0x1, Type=0x2
May-02 1:51:27 PM Z-Wave Z-Stick: Controller firmware version: 3.7
