Limitations of the Zee
    Im working on this project running a Zee1. And the system has started to become slow and heavy. At least it feels really slow. There are not that many modules but a lot of events, as you can see. Does this look like too much for a Zee1? I will probably change and use Zee2 as soon as this is avalible for EU.
    Certified installer for HomeSeer, Control4, KNX and Eaton/xComfort
    It really depends on several factors such as what the events are doing and how often they run. The Zee isn't a CPU demon so if your CPU and memory requirements move up so should your hardware.
    -Rupp
      I tried making so that none is running, more like a trigger. like if motion run an event. if sun over x for x minutes run these events etc.
      Sometimes i can be a bit clogged up.
