Is there a command to use to restart the Zee using putty?
For some reason the system sometimes gets unresponsive. And needs a restart and normally i then have to do this manually by taking the power of the unit.
But when the systems web interface does not respond the system is stil responsive trough putty. So if i could just restart the unit through there i think i could save some time.
