HSM100 won't change to "no motion" state
I believe it is set to the default - 6 minutes? I didn't change that when i installed it.
It is in a fairly high traffic area.
As i recall when i installed it it only ever showed 96% battery level. (bad battery?). All my others show 100% but it worked perfectly and the level didn't change until yesterday when it went down to 91% and started seeing constant motion. (it is now showing 90%)
NeilRunning HS PRO V2.5.0.49 & HS Pro V2.5.0.51
Ok, i changed the batteries last night and it did start working properly again. However it only shows a battery level of 96%
As mentioned in a previous post above that is what it always showed before from when i installed it.
Rupp mentioned a new build where the battery monitoring is fixed, any word on when this will be available?
griffined
I noticed the motion status on my HSM100 was "stuck" on since last night. I pressed the blue button and tried to optimize it, but still it didn't work correctly. My HS system had been up and running for 110 days without issue, since I installed the patch to support the HSM100, so I figured now was as good as any to grab updates and then restart.
Did that, and it's not fixed. Jumped onto this board, and found this thread, so I just replaced the batteries. (When I installed it 3 mos ago it showed 99%, it was showing 94% yesterday, 6 minutes, low to medium traffic area)
Now the motion level is now 97% with the new batteries, and motion is registering correctly.
Call ID: 15131 logged
I found my one HSM100 in constant motion today, 100% battery (last updated 1/11/08). It's normally a low traffic area, but got some high traffic yesterday.
I replaced the batteries. New = 1.55V, Old = 1.44V (all three AAA)
Using settings:
off delay 5 min
led enabled
sensitivity 170
wakeup interval 90 min
New batteries cured it; motion, temp, light lvl all good. Battery level value still has not updated (shows 100% from 6 days ago)
