only 1 reading from HSM100
    I added the HSM100 today, Z-Troller picked it up correctly, it was correctly added to homeseer.
    That's the only time I got any information from it.
    In Setup I changed
    These are the settings under configure:
    Any suggestions?
    2/7/2008 7:44:02 PM  Info **********2/7/2008 7:44:02 PM  Info ********** Adding Z-Wave Device with Node ID of 4 Type NODE_TYPE_SENSOR_MULTILEVEL **********2/7/2008 7:44:02 PM  Info **********2/7/2008 7:44:02 PM  Info Adding Z-Wave device 4 type is 21H2/7/2008 7:44:02 PM  Info Contacting node 4 to get supported features2/7/2008 7:44:02 PM  Info Z-Wave device 4 supports classes: 60,31,70,84,85,80,72,77,862/7/2008 7:44:02 PM  Info Attempting to get manufacturer ID from device 4...2/7/2008 7:44:02 PM  Info Z-Wave manufacturer ID: 0 1E(HomeSeer) Type: 0 2 ID: 0 12/7/2008 7:44:02 PM  Info Z-Wave device 4 version: Lib: 2.31 App: 1.42/7/2008 7:44:03 PM  Info Device supports 1 groups for associations2/7/2008 7:44:03 PM  Info Enabling instant status for Z-Wave device 42/7/2008 7:44:03 PM  Info Setting wake-up interval for device to 3600 seconds.2/7/2008 7:44:03 PM  Info Getting node and location name from device...2/7/2008 7:44:03 PM  Database Item Saving Device 2/7/2008 7:44:03 PM  Info Node did not report it's location or location not set, using the default location.2/7/2008 7:44:03 PM  Info Node did not report it's name or name not set, using the default name.2/7/2008 7:44:03 PM  Info Temperature report for sensor Z-Wave Interface MultiSensor 4 Temperature=78.8 Degrees F2/7/2008 7:44:03 PM  Info Light level report for sensor Z-Wave Interface MultiSensor 4 Light Level=54% Light2/7/2008 7:44:03 PM  Info Battery level report for sensor Z-Wave Interface MultiSensor 4 Battery Level=100%2/7/2008 7:44:03 PM  Info ********** Done with Z-Wave Device with Node ID of 4 **********2/7/2008 7:44:59 PM  Database Item Saving Event UnNamed2/7/2008 7:45:11 PM  Database Item Saving Event UnNamed22/7/2008 7:45:18 PM  Database Item Saving Event UnNamed12/7/2008 7:49:34 PM  Info Event Trigger "UnNamed"2/7/2008 7:49:34 PM  Info Device: Z-Wave Interface Appliance Device 2 (Q1) ON2/7/2008 7:49:37 PM  Info Event Trigger "UnNamed"2/7/2008 7:49:37 PM  Info Device: Z-Wave Interface Appliance Device 2 (Q1) ON2/7/2008 7:50:06 PM  Info Device: Z-Wave Interface Appliance Device 2 (Q1) OFF2/7/2008 7:51:07 PM  Database Item Saving Device MultiSensor 4 Motion2/7/2008 7:52:03 PM  Database Item Saving Device MultiSensor 4 Motion2/7/2008 7:59:45 PM  Info Setting wake-up interval for device MultiSensor 4 Motion to 360 seconds.2/7/2008 8:42:09 PM  Info Web Server authorized local login successful from: 192.168.1.113 User: default2/7/2008 8:42:34 PM  Info Device: Z-Wave Interface Appliance Device 2 (Q1) ON2/7/2008 8:42:37 PM  Info Device: Z-Wave Interface Appliance Device 2 (Q1) OFF
    When I walk into the room, the z-Troller displays the device id (04), but it doesn't trigger the event I have setup for Montion.
    thanks,
    --bjorn
    For whatever reason this started to work the next day.
      Sounds like you may be on the fringe of clear communications. Which Z-Wave receiver are you using and how far is the sensor from this receiver?
        I use a z-troller and it's about 5 feet from the HSM100. I'm currently still investigating how everything works, so no long distance.
          I'll add my $.02
          I installed about 10 switches, receptacles and PIRs today. One was a HSM100. Now as I read on the boards, the PIRs need to be added at their final location.. did that, then brought the HSM back to the main PC (I'm using a HA22 that I yank and slap into the laptop to run ztool) to configure. Once configured I put it back... three hours later no updates from any of the four sensors. Now I highly suspect the HSM has to route over at least one node to hit the controller.
          So I deleted it, readded, and configured while it was in its final location... got all but motion events for a couple hours. So I came here to get the skinny..and oddly enough after the clock hit midnight I started getting motion events.
          I'm not sure if it is by design, but for me all PIRs seem to need some time to "figure things out" before they work fully.
