No temperature below 32F
  • #16
    Oh, and as the temperature rose today, the front yard (facing the sun) sensor moved above zero degrees. When it did so, it started to display correctly. It presently displays 5.9 f in the sunlight. The backyard sensor, shaded, shows 6552.3 degrees. I have a separate weather channel device in the back yard reading -1.7f.
    • #17
      Yea, I would put in a help desk bug report on this.
      -Rupp
      • #18
        Looks like a bug in HS. Note that 65507 is ffe3 in hex or -29 (which I assume is -2.9). So I suspect this is a conversion error in HS. It's not realizing that this is a 2s complement number.
        • #19
          HomeSeer realizes it is a 2's compliment number, but in adding support for values reported with the specified number of bytes, rather than the previously "assumed" values, we shift the bits the appropriate number of positions as we fill a double integer to hold the value, but neglected to look at the sign bit before we shift in the first byte... I will fix it.
          Rick Tinker (a.k.a. "Tink")
          • #20
            Thank you!
