How do I change the No motion timer, temp and light sensor timers? Additionally is it possible to control a device using the temprature
how to change time interval
Hit the red button on the side of the device then go into homeseer, find the parent device and then choose configure. One of the options in there adjusts the timer. Make certain to click the 'Set' button beside the appropriate field after changing the value or it won't stick.
As for controlling using temperature, of course. Create an event that is triggered on value change. Choose your motion detector's temperature sensor node and then enter the value(s) that you want to use to trigger the event.
M
