Eliminate the power source as the problem: Does this unit work on batteries correctly? The voltage is fine, so if it works on batteries then as suggested it's likely noise. You could run a coax cable to power this unit, just ground both ends, that should eliminate the noise.
10 HSM100s How much power?
Noise can cause problems in either AC or DC circuits. If you were to look at a "clean" DC source on a scope it would appear as a straight line. A noisy source would be spiky and look distorted. Clean AC power looks like a perfect sine wave.
In many DC circuits (especially those designed to run off of batteries) there is little to no filtering being done on the power. Many (most?) designers assume battery power will always be clean. Same goes for devices designed to be USB powered since the USB power supply presumably does the filtering.HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
Hardware: Z-NET - W800 Serial - Digi PortServer TS/8 and TS/16 serial to Ethernet - Insteon PLM - RFXCOM - X10 Wireless
Plugins: HSTouch iOS and Android, RFXCOM, BlueIris, BLLock, BLDSC, BLRF, Insteon PLM (MNSandler), Device History, Ecobee, BLRing, Kodi, UltraWeatherWU3
Second home: Zee S2 with Z-Wave, CT101 Z-Wave Thermostat, Aeotec Z-Wave microswitches, HSM200 occupancy sensor, Ecolink Z-Wave door sensors, STI Driveway Monitor interfaced to Zee S2 GPIO pins.
Originally posted by Wadenut View PostIn case of noise, previously mentioned, you guys could consider an electrolytic capacitor inside the battery compartment of each unit. 100 microfarad should be enough.
Originally posted by Koviak View PostI just wanted to report that it looks as if this trick has fixed my problems. Thanks to everyone who has contributed. - Josh
Reid is right; these devices are designed to be supplied with a battery and probably don't have any built in filtering, which is what you've just added.
Using a twisted pair cable next time would help too, but that's another chapter.
Glad the cap worked for you though.Real courage is not securing your Wi-Fi network.
