Contacting HomeSeer This Week
See more
See less
temp & light status changed to "On" after changing battery
  • temp & light status changed to "On" after changing battery
    Changed battery, did rescan, optimized 4 times. Afterwards motion detection works fine, but temp and light status showing as "On" (instead of a numeric value).
    Before changing battery it worked fine. I am running HSPro 2.5.0.29. Any idea what is causing this? Thanks
    Are/were there any errors when you rescanned or optimized?
    -Rupp
      Thanks Rupp. There is time out error when rescan/optimize now. Moving it closer to another node fixes the problem. It's puzzling when battery was first replaced rescan and optimize went fine, and it had been working fine at the same location for a while before I changed the battery last time... do I need to optimize its neighbors as well while HSM100 is awake?
