Contacting HomeSeer This Week
See more
See less
Exception Creating Sensor Multilevel Child Device
  • Exception Creating Sensor Multilevel Child Device
    All:
    I am having trouble adding an HSM100 to my system. I can get the root device and the battery device but nothing else. I've upgraded to 2.5.0.80 and the rescan of the device begins to start correctly.
    6/2/2013 8:13:57 AM Z-Wave Z-Wave device 10 version: Lib: 2.9 App: 1.1
    6/2/2013 8:13:56 AM Z-Wave Z-Wave manufacturer ID: 30=1EH (HomeSeer Tech), Type: 2=2H, ID: 1=1H
    6/2/2013 8:13:56 AM Z-Wave Attempting to get manufacturer ID from device 10...
    6/2/2013 8:13:56 AM Z-Wave Device: Z-Wave Z-Wave Interface Root Device 10 (Node 10) supports class(es): COMMAND_CLASS_MULTI_INSTANCE, COMMAND_CLASS_SENSOR_MULTILEVEL, COMMAND_CLASS_CONFIGURATION_V2, COMMAND_CLASS_WAKE_UP, COMMAND_CLASS_ASSOCIATION_V2, COMMAND_CLASS_BATTERY, COMMAND_CLASS_MANUFACTURER_SPECIFIC, COMMAND_CLASS_VERSION
    But after this I get
    6/2/2013 8:15:20 AM Error Exception creating Sensor Multilevel child device of Z-Wave Z-Wave Interface Child 10, GET for supported sensor types indicated failure.
    6/2/2013 8:15:13 AM Z-Wave Warning Did not get the version number of the Sensor Multilevel command class - the device will likely NOT operate properly.
    Any Help? Also, my Ztroller is on 1.17. I've had these things for several years and they have been troublesome for a long time - just giving them one more go before they go to the trash bin.
    Ken
    How close to your Z-Troller is the device when you wake it up and rescan it?
    -Rupp
      Its about 4 ft away from the ztroller
        Did you wake the device when you rescanned it?
        -Rupp
          How long have you had the sensor? There were some issues with Series 2 sensors - have a half a dozen sensors in the network none with that firmware:
          8 Back-Hallway West Wing Z-Wave Interface Root Device 8 - MB HomeSeer Tech 2 H 1 H False 2.40 (ZDK Version 4.27) App: 1.7 Excellent (35) 40.0Kbps Basic: ROUTING SLAVE
          Generic: SENSOR MULTILEVEL
          MULTI INSTANCE, SENSOR MULTILEVEL, CONFIGURATION V2, WAKE UP, ASSOCIATION V2, BATTERY, MANUFACTURER SPECIFIC, NODE NAMING, VERSION
          16 (Main) Z-Wave Z-Wave Interface Root Device 16 HomeSeer Tech 2 H 1 H False 2.40 (ZDK Version 4.27) App: 1.13 Excellent (54) 40.0Kbps Basic: ROUTING SLAVE
          36 Back-Hallway Z-Wave Z-Wave Interface Root Device 36 HomeSeer Tech 2 H 2 H False 3.40 (ZDK Version 4.54) App: 3.3 Unknown (0) 40.0Kbps Basic: ROUTING SLAVE
          Generic: SENSOR BINARY
          SENSOR BINARY, SENSOR MULTILEVEL, ASSOCIATION V2, ASSOCIATION COMMAND CONFIGURATION, CONFIGURATION V2, WAKE UP, BATTERY, MANUFACTURER SPECIFIC, VERSION
          41 Back-Hallway Outdoors Z-Wave Interface Root Device 41 - 1st Bedrm Outside HomeSeer Tech 2 H 1 H False 2.40 (ZDK Version 4.27) App: 1.13 Excellent (25) 40.0Kbps Basic: ROUTING SLAVE
          75 Back-Hallway Z-Wave Z-Wave Interface Root Device 75 HomeSeer Tech 2 H 1 H False 2.40 (ZDK Version 4.27) App: 1.11 Excellent (49) 40.0Kbps Basic: ROUTING SLAVE
          102 (Main) Outdoors Z-Wave Interface Root Device 102 HomeSeer Tech 2 H 1 H False 2.40 (ZDK Version 4.27) App: 1.11 Acceptable (37) 40.0Kbps Basic: ROUTING SLAVE
            Well I'm trying a different set up while I'm ramping up on HS3.
            Instead of my ztroller/HS2 I've tried Aeon Labs zstick/HS3. The device is within 2 ft of the zstick and I have pushed the button.
            Results trying to rescan the device from HS3:
            Synchronizing network information against HomeSeer devices...
            Getting Z-Wave node list for network 00006773...
            Found 2 Z-Wave nodes
            Syncing Z-Wave nodes with device list...
            ... Checking node list against existing devices, node 1 done.
            ... Checking node list against existing devices, node 2 done.
            Synchronize nodes finished. Number of device nodes to be created/added = 0
            Device synchronization does not need to create any new SECURE devices.
            Device synchronization needs to create 1 device.
            Warning: Node 2 did not respond to a request for the Command Class Version for MULTI_INSTANCE/MULTI_CHANNEL
            Warning: The device at node 2 should result in 2 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
            Finished with Z-Wave device synchronization.
              I just got HS3 up and running and got the interface up and when I do a full scan on my 31 zwave devices, mostly Cooper Aspire switches and several Aeon Energy Smart Switches along with a few sensors, I get the same errors as you for all devices that should have children and these children never do get created in the device list, here is my log from a full scan:
              Operational messages will appear here...
              Loading network information from your Z-Wave interface...
              Done.
              Getting Z-Wave node list for network XXXXXXXX...
              Found 31 Z-Wave nodes
              ... Checking node list against existing devices, node 3 done.
              ... Checking node list against existing devices, node 4 done.
              ... Checking node list against existing devices, node 8 done.
              ... Checking node list against existing devices, node 9 done.
              ... Checking node list against existing devices, node 20 done.
              ... Checking node list against existing devices, node 21 done.
              ... Checking node list against existing devices, node 22 done.
              ... Checking node list against existing devices, node 23 done.
              ... Checking node list against existing devices, node 24 done.
              ... Checking node list against existing devices, node 25 done.
              ... Checking node list against existing devices, node 26 done.
              ... Checking node list against existing devices, node 27 done.
              ... Checking node list against existing devices, node 28 done.
              ... Checking node list against existing devices, node 29 done.
              ... Checking node list against existing devices, node 30 done.
              ... Checking node list against existing devices, node 33 done.
              ... Checking node list against existing devices, node 34 done.
              ... Checking node list against existing devices, node 36 done.
              ... Checking node list against existing devices, node 37 done.
              ... Checking node list against existing devices, node 39 done.
              ... Checking node list against existing devices, node 43 done.
              ... Checking node list against existing devices, node 44 done.
              ... Checking node list against existing devices, node 45 done.
              ... Checking node list against existing devices, node 46 done.
              ... Checking node list against existing devices, node 47 done.
              ... Checking node list against existing devices, node 48 done.
              ... Checking node list against existing devices, node 49 done.
              ... Checking node list against existing devices, node 50 done.
              ... Checking node list against existing devices, node 51 done.
              Synchronize nodes finished. Number of device nodes to be created/added = 31
              Device synchronization needs to create 1 SECURE device.
              Device synchronization needs to get Z-Wave class information for 1 SECURE node.
              Warning: Failed to retrieve Z-Wave class information for node 50, device synchronization/creation will not continue for this node.
              Z-Wave manufacturer information for node 2, ID: 144=90H (Black & Decker), Type: 1=1H, ID: 1=1H
              Negotiating SECURITY SCHEME for node 2
              Warning: Failed to get SECURITY SCHEME from node 2. Device may not be added properly to HomeSeer.
              Warning: The security device may have a timeout when adding to the network, bring the device close to HomeSeer and use the Add Node button to add it (remove it first)
              Warning: If this device was previously added to the network, the device may need to be removed from the network and re-added.
              Warning: In case the device was previously added successfully, an attempt will be made to contiunue the import.
              Getting SECURITY class information for node 2
              Error: Retrieval of security class information reported successful, but there is no security class information present - cannot continue loading node 2
              Device synchronization needs to create 28 devices.
              Device synchronization needs to get Z-Wave class information for 28 nodes.
              Z-Wave manufacturer information for node 3, ID: 26=1AH (Cooper Wiring), Type: 22349=574DH, ID: 0=0H
              Z-Wave manufacturer information for node 4, ID: 26=1AH (Cooper Wiring), Type: 17481=4449H, ID: 0=0H
              Z-Wave manufacturer information for node 8, ID: 26=1AH (Cooper Wiring), Type: 17481=4449H, ID: 0=0H
              Z-Wave manufacturer information for node 9, ID: 26=1AH (Cooper Wiring), Type: 17481=4449H, ID: 0=0H
              Z-Wave manufacturer information for node 20, ID: 26=1AH (Cooper Wiring), Type: 17481=4449H, ID: 0=0H
              Z-Wave manufacturer information for node 21, ID: 26=1AH (Cooper Wiring), Type: 21324=534CH, ID: 0=0H
              Z-Wave manufacturer information for node 22, ID: 26=1AH (Cooper Wiring), Type: 21324=534CH, ID: 0=0H
              Z-Wave manufacturer information for node 23, ID: 26=1AH (Cooper Wiring), Type: 21324=534CH, ID: 0=0H
              Z-Wave manufacturer information for node 24, ID: 26=1AH (Cooper Wiring), Type: 21324=534CH, ID: 0=0H
              Z-Wave manufacturer information for node 25, ID: 26=1AH (Cooper Wiring), Type: 22349=574DH, ID: 0=0H
              Z-Wave manufacturer information for node 26, ID: 26=1AH (Cooper Wiring), Type: 17481=4449H, ID: 0=0H
              Z-Wave manufacturer information for node 27, ID: 26=1AH (Cooper Wiring), Type: 17481=4449H, ID: 0=0H
              Z-Wave manufacturer information for node 28, ID: 26=1AH (Cooper Wiring), Type: 22349=574DH, ID: 0=0H
              Z-Wave manufacturer information for node 29, ID: 26=1AH (Cooper Wiring), Type: 17481=4449H, ID: 0=0H
              Z-Wave manufacturer information for node 30, ID: 26=1AH (Cooper Wiring), Type: 21330=5352H, ID: 0=0H
              Z-Wave manufacturer information for node 33, ID: 134=86H (Aeon Labs), Type: 3=3H, ID: 6=6H
              Z-Wave manufacturer information for node 34, ID: 134=86H (Aeon Labs), Type: 3=3H, ID: 6=6H
              Z-Wave manufacturer information for node 36, ID: 134=86H (Aeon Labs), Type: 3=3H, ID: 6=6H
              Z-Wave manufacturer information for node 37, ID: 134=86H (Aeon Labs), Type: 3=3H, ID: 6=6H
              Z-Wave manufacturer information for node 39, ID: 26=1AH (Cooper Wiring), Type: 17481=4449H, ID: 0=0H
              Z-Wave manufacturer information for node 43, ID: 26=1AH (Cooper Wiring), Type: 17481=4449H, ID: 0=0H
              Z-Wave manufacturer information for node 44, ID: 26=1AH (Cooper Wiring), Type: 17481=4449H, ID: 0=0H
              Z-Wave manufacturer information for node 45, ID: 26=1AH (Cooper Wiring), Type: 17473=4441H, ID: 0=0H
              Z-Wave manufacturer information for node 46, ID: 26=1AH (Cooper Wiring), Type: 17473=4441H, ID: 0=0H
              Z-Wave manufacturer information for node 47, ID: 26=1AH (Cooper Wiring), Type: 22349=574DH, ID: 0=0H
              Z-Wave manufacturer information for node 48, ID: 26=1AH (Cooper Wiring), Type: 22349=574DH, ID: 0=0H
              Z-Wave manufacturer information for node 49, ID: 275=113H (Evolve), Type: 17488=4450H, ID: 12336=3030H
              Z-Wave manufacturer information for node 51, ID: 275=113H (Evolve), Type: 17488=4450H, ID: 12336=3030H
              Error: Cannot get additional details about node 3 as there is no node information available.
              Error: Cannot get additional details about node 4 as there is no node information available.
              Error: Cannot get additional details about node 8 as there is no node information available.
              Error: Cannot get additional details about node 9 as there is no node information available.
              Error: Cannot get additional details about node 20 as there is no node information available.
              Error: Cannot get additional details about node 21 as there is no node information available.
              Error: Cannot get additional details about node 22 as there is no node information available.
              Error: Cannot get additional details about node 23 as there is no node information available.
              Error: Cannot get additional details about node 24 as there is no node information available.
              Error: Cannot get additional details about node 25 as there is no node information available.
              Error: Cannot get additional details about node 26 as there is no node information available.
              Error: Cannot get additional details about node 27 as there is no node information available.
              Error: Cannot get additional details about node 28 as there is no node information available.
              Error: Cannot get additional details about node 29 as there is no node information available.
              Error: Cannot get additional details about node 30 as there is no node information available.
              Error: Cannot get additional details about node 33 as there is no node information available.
              Error: Cannot get additional details about node 34 as there is no node information available.
              Error: Cannot get additional details about node 36 as there is no node information available.
              Error: Cannot get additional details about node 37 as there is no node information available.
              Error: Cannot get additional details about node 39 as there is no node information available.
              Error: Cannot get additional details about node 43 as there is no node information available.
              Error: Cannot get additional details about node 44 as there is no node information available.
              Error: Cannot get additional details about node 45 as there is no node information available.
              Error: Cannot get additional details about node 46 as there is no node information available.
              Error: Cannot get additional details about node 47 as there is no node information available.
              Error: Cannot get additional details about node 48 as there is no node information available.
              Error: Cannot get additional details about node 49 as there is no node information available.
              Error: Cannot get additional details about node 51 as there is no node information available.
              Warning: The device at node 2 should result in 3 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
              Warning: The device at node 3 should result in 2 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
              Enabling instant status for Z-Wave device Z-Wave Node 4 Z-Wave Interface Cooper Wiring Switch Multilevel Node 4 (Node 4, Group 255)
              Enabling instant status for Z-Wave device Z-Wave Node 8 Z-Wave Interface Cooper Wiring Switch Multilevel Node 8 (Node 8, Group 255)
              Enabling instant status for Z-Wave device Z-Wave Node 9 Z-Wave Interface Cooper Wiring Switch Multilevel Node 9 (Node 9, Group 255)
              Enabling instant status for Z-Wave device Z-Wave Node 20 Z-Wave Interface Cooper Wiring Switch Multilevel Node 20 (Node 20, Group 255)
              Enabling instant status for Z-Wave device Z-Wave Node 21 Z-Wave Interface Cooper Wiring Switch Binary Node 21 (Node 21, Group 255)
              Enabling instant status for Z-Wave device Z-Wave Node 22 Z-Wave Interface Cooper Wiring Switch Binary Node 22 (Node 22, Group 255)
              Enabling instant status for Z-Wave device Z-Wave Node 23 Z-Wave Interface Cooper Wiring Switch Binary Node 23 (Node 23, Group 255)
              Enabling instant status for Z-Wave device Z-Wave Node 24 Z-Wave Interface Cooper Wiring Switch Binary Node 24 (Node 24, Group 255)
              Warning: The device at node 25 should result in 2 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
              Enabling instant status for Z-Wave device Z-Wave Node 26 Z-Wave Interface Cooper Wiring Switch Multilevel Node 26 (Node 26, Group 255)
              Enabling instant status for Z-Wave device Z-Wave Node 27 Z-Wave Interface Cooper Wiring Switch Multilevel Node 27 (Node 27, Group 255)
              Warning: The device at node 28 should result in 2 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
              Enabling instant status for Z-Wave device Z-Wave Node 29 Z-Wave Interface Cooper Wiring Switch Multilevel Node 29 (Node 29, Group 255)
              Enabling instant status for Z-Wave device Z-Wave Node 30 Z-Wave Interface Cooper Wiring Remote Switch Node 30 (Node 30, Group 1)
              Warning: The device at node 33 should result in 3 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
              Warning: The device at node 34 should result in 3 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
              Warning: The device at node 36 should result in 3 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
              Warning: The device at node 37 should result in 3 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
              Enabling instant status for Z-Wave device Z-Wave Node 39 Z-Wave Interface Cooper Wiring Switch Multilevel Node 39 (Node 39, Group 255)
              Enabling instant status for Z-Wave device Z-Wave Node 43 Z-Wave Interface Cooper Wiring Switch Multilevel Node 43 (Node 43, Group 255)
              Enabling instant status for Z-Wave device Z-Wave Node 44 Z-Wave Interface Cooper Wiring Switch Multilevel Node 44 (Node 44, Group 255)
              Enabling instant status for Z-Wave device Z-Wave Node 45 Z-Wave Interface Cooper Wiring Remote Switch Node 45 (Node 45, Group 1)
              Enabling instant status for Z-Wave device Z-Wave Node 46 Z-Wave Interface Cooper Wiring Remote Switch Node 46 (Node 46, Group 1)
              Warning: The device at node 47 should result in 2 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
              Warning: The device at node 48 should result in 2 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
