No response messages
    Flooded with 'No response' messages at my HSM100 after moving my Z-Wave controller to another serial port. Still works though...
    I went from a Quatech Serial Device Server to Edgeport Serial Server, hoping that isn't the issue.
    Don
    I'd try pulling the batteries from the sensor and doing a restart on the ZTroller first. If that fails, check to make sure the com port settings are good.
    HS4Pro on a Raspberry Pi4
    54 Z-Wave Nodes / 21 Zigbee Devices / 108 Events / 767 Devices
    Plugins: Z-Wave / Zigbee Plus / EasyTrigger / AK Weather / OMNI
    HSTouch Clients: 1 Android
      Good idea, happen to know what the port settings are?
      Don
        Baud rate is 115k, No parity, 8 bits, 1 stop bit.
        Let us know if that works or not...
          Thanks, had it at 9600. Will let you know if it helps.
          --- Later
          Still getting errors, but it's a lot better.
          Don
            With HS2 V80 I found that I cannot make any changes to the serial port connection en vivo to the Z-Troller. Any changes; IE: disconnecting and reconnecting it or switching ports while HS is running.
            Whatever I changed would cause the Z-Troller plugin not to work.
            Easier to configure the port, shut down HS and restart HS and you should be OK.
            The port speed should auto set itself once that the Z-Troller is connected and talking to HS.
            Just noticed with HS3 that one serial device disconnect disconnects the rest of the devices plugged in and I get command boxes for each of the connections popping up and none work. But that is me and right now just have plugins installed and disabled. I was trying to connect one at a time turning on each by itself.
            - Pete
            Auto mator
            HS4 Pro - Ubuntu 22.04 / Lenova Tiny M900 / 32Gb Ram
