I read on a thread somewhere here that you can put rechargeable batteries in an HSM100 that is powered by a wallwart and it will power the unit + charge the batteries. So I tried this, the batteries got real hot so I removed them before something blew up. I assume the power supply was too much for the batteries (5 volt).
Now I find this little $3.00 battery charger on eBay. It has tabs for wires or it can be powered by the usb connector on board. It arrived yesterday and I anxiously attached it to a HSM100 - put the batteries in and it is working!
Read the item description... Almost perfect, good enough I think...
eBay item # 170962572366
http://www.ebay.com/itm/170962572366
The LED is red while the batteries charge, green when they are charged. There is enough power left over to run the unit, too.
It is pretty tiny, batteries seem happy, have not mounted it inside yet.
What do you people think?
This also makes the HSM100 USB powered, if desired...
