HSM100-S3 + HS3 Basic Questions
  • #16
    Hi Al,
    OK, It works now. I removed the device from the z-wave network again but using the "Best Method" described here:
    http://board.homeseer.com/showthread.php?p=1036607
    I did this with the sensor sitting on top of the Hometroller and running on battery power instead of a wall wart (I don't know if this last part made any difference). Previously I performed the "Alternate Method". Also, I added back it using the Add Node function under the Setup>Interfaces>Manage page. After pressing the Add Node button, I pressed the blue button on the sensor. The detector first came up as the battery. So I had 2 batteries for awhile. I did a rescan and optimized the node 4 times, set the sensor to come on every 6 minutes and ate some lunch. After lunch I noticed that all 4 outputs seem to be functioning correctly and the motion detector is no longer an ON/OFF device.
    So I guess all is well now. Thanks for the help.
    Robert
    • #17
      You're welcome. Glad it's working now.
      Cheers
      Al
      HS 3.0.0.548: 1976 Devices 1156 Events
      Z-Wave 3.0.1.262: 123 Nodes on one Z-Net
