best alternate to HSM100?
  • #16
    Aeotec Multi Sensor
    I've had the Aeotec Multi Sensor for a week now and have been blown away with the accuracy and coverage from this thing. I was surprised to see in the instructions that it could be ceiling mounted. So that's what I did...I mounted it on the ceiling in the middle of my kitchen and it hasn't missed a beat. Hopefully this week I'll get into the attic and run a USB cable over to it and power it that way.
    I like so much, I have 2 more units coming tomorrow!
    Bryan
    Software/Hardware: Win10 Pro, HS 3 Pro, HS Touch, Echo, Edgeport/4, Z-Net w/88 Devices, Insteon PLM w/19 Devices, Nest, GC-100-6, W800RF32A, WS-2080 Weather Station (KMADRACU10)
    Plug-in/Scripts: Alexa API, BLBackup, BLGData, BLLED, BLLock, BLRF, BLTVGuide, Blue Iris, BLUPS, Current Cost 3P, DirectTV, FitbitSeer, Insteon, Nest, Pushover 3P, Random, Restart, Tasker, UltraGCIR3, UltraWeatherWU, Z-Wave
    • #17
      Originally posted by DMcKnight View Post
      I was speaking with one of the people at HST the other day and he mentioned that the new, to-be-announced multisensor would plug in a wall socket. That would be nice for certain locations, but I hope it has an option for battery power, or at least for running a thin low voltage supply cable...
      Doug
      I probably wouldn't buy one if it had to be plugged in a wall socket.
      • #18
        That's not very pet-proof either. Hmmmm...
        Sent from my SCH-R970X using Tapatalk
        • #19
          I could see a dog chewing on it or a cat rubbing his face one it. I don't have a lot of free sockets either. If there is not a night light or a Glade air freshener or a lamp plugged in, it's either blocked by a couch or not located in a good location for a sensor.
          Also, I have replaced a dozen or so outlets with z-wave outlets and I plan to replace more which leaves only the top socket for an always on device.
          • #20
            it's true.. we're coming out with an externally powered unit (HSM200). The module is designed to be powered by 120v. Some nice benefits:
            • No batteries to replace
            • Timeout and data reporting intervals can be very short
            • The unit functions as a repeater (battery-powered devices cannot)
            • A programmable multi-colored LED is installed under the lens. You can program events to change the LED color based on any trigger/condition
            • Unit can be programmed to function as a night light
            • #21
              Really interesting. I can agree with some of the downsides listed above, but can also see some interesting utility in the design. There are definitely places I could use these.
              Randy Prade
              Aurora, CO
              Prades.net
              • #22
                They do sound interesting. I'm pondering where I could use them. I need an electrical outlet located in the right location. I like sensors located high up on a wall to look over obstacles.
                • #23
                  HSM 100 - Not availiable.
                  Hi all,
                  I am in the UK and have been using EZ Motion sensors, these are just badge engineered HSM 100's or the other way around! I run them off a 5v supply and they have proved excellent as motion sensors. The price also seems to have dropped quite alot recently which helps. The temperature settings seem to run a little on the high side through.
                  Hope this helps.
                  Peter
                  • #24
                    Right, they're not going to be as convenient to mount as battery operated units... so they won't work for every application. I think they'd be really good in hallways (especially dark hallways), kitchens & bathrooms & garages & basements (where outlets are generally higher).
                    • #25
                      It also might be worthwhile to mount a duplex outlet up high in the family/living room and let the LED notify my wife when the washing machine or dryer is done. Some of us might even find that there is an X-volt power supply inside that could be remotely mounted with a couple of low voltage wires to the unit.
                      But that would be so wrong
                      Randy Prade
                      Aurora, CO
                      Prades.net
