Project File
    Project File
    Is the stock WFTT07 project file available?
    -Tim
    HSPro - 3.XXX - Dell mini W7 x32
    Way2 Call
    Elk M1 Gold
    UPB HAI switches
    HAI RC2000 Thermostat
    Any luck in finding the stock WFTT07 project file? I just installed the latest designer and the tabletop project that is there seems to be lacking a couple of things.
    I just need to add/modify a few things and don't want to lose some of new features of the latest project.
      Here's one way to get it:
      --open the .apk file (hint - rename it with a .zip extension)
      --browse to the res\raw folder
      --open the resources.zip
      You will see Android-Landscape.xml. Thats the project file.
      Note there is also a Tabletop folder - you need that in your designer's skins folder to pick up the graphics.
      72 Z-Wave Nodes, 111 Events, 422 Devices
      Z-Wave, UPB, WiFi
      Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
        You can utilize WinSCP changing files around via a Wintel desktop over the Android device running openSSHserver.
        I have added fonts to the base just copying them over.
        - Pete
        Auto mator
        Fanless IntelĀ® Celeron N3160 SoC 8Gb
          Hi,
          Anyone has a zip of the whole project, and wants to share :P?
          Regards Bart
          Win7 64Bit on Intel NUCI7 with SSD
          HSPRO 3.
          Devices; 1370 Events; 691
          Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
          Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
