Originally posted by macromark
View Post
New Control Pad 2 Tabletop Touchscreen!
This is a sticky topic.
It is running standard Android, but if you can get other voices on other Android devices, I assume you can install them on this one. We do not include any app store, but you can side load the Amazon App Store for installing apps, or side load any APK file.
Originally posted by jmj09 View PostLooks interesting, will it run on a european network? I guess it will, since it relies on Wifi... Does it include european voices ?
JMJ
Originally posted by rjh View PostIt is running standard Android, but if you can get other voices on other Android devices, I assume you can install them on this one. We do not include any app store, but you can side load the Amazon App Store for installing apps, or side load any APK file.Bryan
Software/Hardware: Win10 Pro, HS 3 Pro, HS Touch, Echo, Edgeport/4, Z-Net w/88 Devices, Insteon PLM w/19 Devices, Nest, GC-100-6, W800RF32A, WS-2080 Weather Station (KMADRACU10)
Plug-in/Scripts: Alexa API, BLBackup, BLGData, BLLED, BLLock, BLRF, BLTVGuide, Blue Iris, BLUPS, Current Cost 3P, DirectTV, FitbitSeer, Insteon, Nest, Pushover 3P, Random, Restart, Tasker, UltraGCIR3, UltraWeatherWU, Z-Wave
Mark,
Where can we get the images so we can update/add to this theme in designer? I want to add IR control for TV?
Also worth mentioning the energy button doesn't work in HS2 (even though I do have a current cost unit)
Dan.Last edited by dmurphy; December 13, 2014, 12:17 PM.HS3 Pro Edition 3.0.0.435 (Windows 10 vmware)
BLOccupied:,UltraNetCam3:,weatherXML:,RFXCOM:,Current Cost 3P:,UltraGCIR3:
DMMQTT:,Kodi:,Z-Wave:,BLRadar:,EasyTrigger:,MySensors:,BLBackup:
Just got mine today. Very nice unit.
It's running Kitkat 4.4.2. There was no Play Store installed, so I side installed the lastest version (5.0.32) via SD Card with no problem. Unfortunately, it doesn't seem to work as it keeps crashing every time I try to update an app. Good news is that so far I have been able to sideload apps without any problem.
Someone asked about the camera. I side loaded Google Camera and it works fine on this unit (which has an A23 dual core processor). It is taking 1600X1200 pictures (UXGA) and taking H264 - MPEG 4 video at the same resolution at 6.15 fps.
Very nice unit overall. Congrats to everyone Homeseer on getting out a nicely refreshed unit at a very reasonable price!
Has anybody updated to the new design? Mine does not indicate their is an update as mentioned on page 4 of the instructions that came with the Tabletop. I also question why a 90 degree power plug was provided that interferes with the tabletop sitting flat on a table? a straight plug would have been a better choice.
papester
I was able to update to the new design without an issue, although I use my own design so I replaced the stock one after updating.
I agree on the cord. The first version had a cord that went straight out, this 90 angle one is not the right design. I had to push mine hard to the side so that the unit would sit flat. It works, but can't be good for the cord. I do like that the plug is now a 90 degree design. If they could combine the new plug with the old cord that would be best!
the Google Play Store is not licensed for use on this unit. As such you may not be able to load that. You can however sideload the Amazon app store on to the unit. That will work.the project file and the images for the new GUI will be included in the next release of the designer.the angled power supply connector helps to add stability to the unit when you push on the screen.
