I have two WFTT07's. I want to make different events that are triggered by one or the other using the same Labeled button that is displayed on each. So if I push a Buttoned Labeled "Door Locks" I want to know which WFTT07 that command came from and trigger the event I want to run from that controller.
I know I could upload different programs to each to overcome this issue but that just makes more work in keeping each up up to date as basically they are the same except for one action that I want to happen different depending on which controller the button was pushed.
Is there away to tell which WFTT07 the command came from without each WFTT07 having different programs.
