Intermatic HA05 Will Not Link w/ Z-Troller
    I just bought a half-dozen HA05 screw-in type modules for my basement lights -- they will not link with my Z-Troller controller. I press the 'Add' button on the Z-troller, then toggle the power button on the HA05 -- and nothing happens. I've tried with two different HA05 units. Is there some special technique needed to link the HA05 to the Z-Troller, or have I just wasted a whole bunch of money?
    Try Deleting the device before you add...
    72 Z-Wave Nodes, 111 Events, 422 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      That did it!
      Thanks VERY much for the quick response!
      -M.
        No problem - I had the same problem with z-wave devices. Sometimes the Z-Troller just likes to be pampered a little
        Z-Wave, UPB, WiFi
          I just purchased an HA05 for testing to extend my network outside. I cannot get this thing to go into program mode. Here are the instructions:
          Make sure the lamp plugged into the module
          is switched ON, then press and release the
          PROGRAM button (the black button) on the
          module till the lamp comes ON. The green LED
          on the module will blink.
          It doesn't blink. Defective?
            I just dug this unit up and tried to add it again. I was able to add it with the Z-Troller that imported it into Homeseer. I get...
            Loading network information from your Z-Wave interface... Done.
            Synchronizing network information against HomeSeer devices...
            The Z-Wave network has 36 nodes.
            Found node 48. Retrieving class and manufacturer information from the node.
            Failed to get basic node information from new node 48, cannot continue to load this node.
            Finished with Z-Wave device synchronization.
            It now shows up in the list of Z-wave nodes as a Zwave Node with No Homeseer Device?
            I removed and added several times and get the same thing every time.
            Any thoughts? Thanks.
