Z-troller swap
    Z-troller swap
    I need to swap the existing Z-Troller with a new one. What is the best way to do this without having to capture all the nodes and re-program the HSTouch interface, etc.
    Appreciate any help I can get...Cheers
    Navigate to the Z-Wave Management Page (Setup>Interfaces>Manage Button) and click the "backup network" button to backup your original Z-Troller’s network information to a file. Switch out the Z-Trollers and restart HomeSeer then using the path above, click the "restore network" button to restore your Z-Wave network back to your new Z-Troller. Restart HomeSeer.
    -Rupp
      I think all you need to do is just backup the first controller, then restore that backup to the new controller.
      Now as I type this, I'm wondering if the unique Home ID on the Ztroller is transferred or not during a restore. You might have to test this for us
      72 Z-Wave Nodes, 111 Events, 422 Devices
      Z-Wave, UPB, WiFi
      Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
        Thanks guys. Will do as recommended and post results.
          moving from a Z-Stick to a Z-troller.. can the move be as easy as backing up the stick and downloading to the troller ???
          Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
            cmon u want it that easy!?!?!!?!??!
            hope it is that easy for ya!
            im gonna redo my ENTIRE HS install including wiping my z-troller!!!! and nodes
              deserve easy.. just upgraded my DSC 1832 to ver 4.6, still not up
                Sorry but this is not possible. The Z-Stick does not have the "installer" library and that is required to do a network backup.
                Learn About HomeSeer
                  soooo.. I will be starting from a blank slate ? re-enroll every node ?
                    Correct and don't forget to use the delete functionality prior to adding the devices to your new controller.
                    -Rupp
                      and i did this why
                      ok.. using HS, delete all devices, change controller, add all nodes to new controller...
                      the instructions say I can use the Z-troller to delete the old nodes, then re-add ??
                        I am missing something
                        went from node to node, removed using z-tool
                        went back to HS box. did import
                        did rescan
                        did optimize
                        all the nodes still show on who am I
                        but optimize shows I removed nodes, count down from 32 to 14 ???
                          do I need to go to status page and delete each node I removed from controller ?
                            moving on.. just noticed
                            I have been removing "devices" not removing "nodes"
                            is this where I went south ??
                              On a related note:
                              When I look inside the backup file, I only see what looks like Zwave and HS config values, nothing that would look like a routing table.
                              I'm assuming the internal routing table will be lost if a new controller is installed (ie your network will probably be unstable for some time until the controller relearns all of the routes (ie multiple Optimize??))
                              Z
