ZWSTAT Thermostat -> Z-Troller ... missing something simple
    Hey guys ... I've finally got my ZWSTAT thermostat installed and I've followed the Z-Wave connection instructions with no success. The Z-Troller scans then stops and displays 6 50 ... the ZWSTAT just sits saying "Adding device ... wait". Five minutes of waiting and no apparent connection.
    Here's what I did:
    1. Turn thermostat to rf10
    2. Hold down ADD/SCAN on Z-Troller
    3. Press 1 on thermostat to initiate the connection
    ... eventually, the Z-Troller goes to sleep and nothing changes on the thermostat. I also tried flipping step 2 & 3 ... same result.
    I know I must be missing something easy. Any pointers?
    Thanks in advance!
    Thermostats need to be added with the Z-Troller attached to the HS computer and use the Z-Wave management functionality.
    -Rupp
      Hey, Rupp ... so, I would leave the Z-Troller plugged into HS and try to connect it up with the ZWSTAT? Is that right?
        I'm not finding how to connect up the ZWSTAT to Z-Wave. Are there steps somewhere?
          Try removing the zwstat from the network before adding it - have seen numerous devices from manufacturers already on a network.
          2. Hold down Delete on the Z-Troller
          3. To remove the thermostat from the Z-Wave network select 0.
            It depends on your stat. There should be instructions that came with the stat that states how to include the device in the network.
            -Rupp
              Thanks for the continued help, Rupp.
              Here are the instructions I've been gvien:
              1. The instructions with the Z-Troller say to disconnect it from HS and take it to the device to add it.
              2. The instructions with the ZWSTAT say to press the "INCLUDE" button on the Z-Wave Controller ... there's no INCLUDE, just ADD/SCAN, which doesn't accomplish the mission.
              3. In the quote above, you directed me to not disconnect the Z-Troller, but use the Z-Wave management functionality.
              I have NO idea how to proceed as all three of those instructions contridict each other in some respect.
              I'm at a complete loss ... and I'm a software engineer.
                The Add/Scan button on the Z-Troller is the Include button - Press and hold - Z-Troller display will read Add
                Not sure why this was stated only have had to do this with certain Z-Wave Locks(kwikset and yale) never with a thermostat from any manufacturer
                As stated above you might try deleteing from the network(resetting the Z-Wave chip) before trying to add it to your network - what could it hurt
                  Hey, guys ... as a test, I bought a wall plug Z-Wave device ... hoping to isolate which (the Z-Troller or the ZWSTAT) is not functioning properly.
                  The Z-Troller connected up without issue to the binary wall plug, sooooo ... I guess it's the ZWSTAT that has the issue. Either the ZWSTAT or me.
                  Additional help would be appreciated ... I'm about to give up.
