HS not seeing manufacture information
    I replace my defective z-troller about a month or 2 ago and it was working fine. In the last couple of weeks I started noticing issues with nodes losing connectivity. I restarted the server and HS. When HS came back up, I noticed that HS did not recognized the HTroller. It has "controller manufacture unknown - ID=0x354A Type=0x7F58" The version number is .096
    Also when I looked at my nodes, it had my Leviton controllers listed as ACT devices. I cannot add in my new HS motion detector (can not read manufacture, etc).
    Has anybody seen this?
    I am running 2.5.0.80
    Thanks in advance
    Mike
    Thanks in advance
    Mike
    I have lots 5 ACT HomePro nodes that all have "controller manufacture unknown " and will not work with homeseer.
    Greig
    Scripts =
    Various
      Greig:
      Yes, I have a few very old ACT devices that will not show up. The issue is that I have Leviton Controllers that are showing up as ACT controllers. (identity crisis). The controllers are not acting correctly as well.
      Mike
        Greig:
        Mike
        I wander if it is just a Identity problem in homeseer and not my devices like I first thought.
        Are you going to put in a bug report for this as I would love to get my devices working again. I will add to it if needed and do any testing required.
        Greig.
        Scripts =
        Various
