How do I add a vacation home to HS3?
    I currently run 2 different HS systems, one in my primary and one in my vacation home. I would like to consolidate to one HS system, hopefully to achieve better reliability and serviceability. I don't want to have to drive 200 miles to re-boot or restart a computer that's hung.
    I see several references to this scenario in HS3 documentation, but have not yet figured out exactly how to do it. How do you reliably connect a z-troller with an Ethernet interface through your router and cable modem when you are using dynamic IP addresses? Do I need to set up a VPN (I have no experience in that)?
    Does anyone have a second house connected to your system? Please share your setup and experience.
    Johan
    This might be a good fit for the Zee. Instead of running HS at House A and the ZTroller living at House B, leave everything at House B and just access it over the web.
    For the random hang issue, you could put it on a timer for daily reboots, etc.
    72 Z-Wave Nodes, 111 Events, 422 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      You just made Mark's day
      Z
        Z
        Ha!
        Z-Wave, UPB, WiFi
          Actually, now that I think of it, is there a way to interface the Zee into a "primary" HS3 system?
          Having a little more smarts at the remote location isn't such a bad thing if you could also map that data into an HS3 system..
          Z
            Here thinking of maybe installing a Zee inside of one of two cans today.
            I have configured one router, patch panel, sound stuff et al in one Leviton can. Thinking that the Zee will still fit nicely inside said can but can go to the second can easily. I do have an AP in the attic above the wiring closet and could just stick the Zee with it if I utilize the Aeon stick on it.
            Personally I would still prefer an autonomous HS3 set up though with connections over to primary HS3 box.
            - Pete
            Auto mator
            Fanless IntelĀ® Celeron N3160 SoC 8Gb
              Z
              Yes.. a Zee would probably be a good fit for this. Feel free to call us directly if you want to discuss in greater detail. 603-471-2816
              Learn About HomeSeer
                Why not send a bridged VPN style connection between the two sites, then use Serial/USB to network devices to pass over to the primary (main) HS3 server?
                HS3 PRO, Win10, WeatherXML, HSTouch, Pushover, UltraGCIR, Heaps of Jon00 Plugins, Just sold and about to move so very slim system.
                Facebook | Twitter | Flickr | Google+ | Website | YouTube
                  Yup; Thank-you Travis.
                  I utilize a tunnel today that I set up with DD-WRT to get to my stuff there and that would work for running a single plugin there talking here or using a serial over the WAN connection. I am currently just bridging a connection on the FIOS combo box there (which in still in the can and working after some 5 years now). I did just recently replace the DD-WRT box as the radio went bad on it. Everything on it continued to work fine. Batteries though have to be replaced on the weather station as of October this year.
                  All I have really running there is a Cumulus server and a couple of other boxes. I get almost live data over to the HS2 box now by posting a csv file out to the internet; then retrieve here. Mostly just watch the weather there today. A custom HSTouch connection to the box there would probably be fine. I left an IP camera and Omnistat there on my last visit there and never installed it. We did have a Manatee decide to live under the boat dock one year. We had to build a new dock afterwards. We never really use the dock there.
                  This would be more of an experiment as I have wanted to put a HS box there for a few years now (like 10); just never got around to it. The wiring closet is small just a few inches on either side of the cans. One can high up and another one right below it.
                  - Pete
                  Auto mator
