I measured two of the unregulated power supplies (each individually) that come packaged with the z-troller. I rigged some kit to measure their voltage output with a z-troller connected and operating. I used a Fluke 87V multimeter to take the measurements (for this purpose, it is plenty accurate), and it measured between 8.5 to 9 volts. The nominal voltage stamped on each of the power supplies is 6 volts.
I notice that the recommended replacement power supply for a z-troller is a 5 volt regulated power supply: http://store.homeseer.com/store/Syst...faces-C66.aspx Therefore, it would be putting out 5 volts with the z-troller connected and operating, not 8.5 to 9 volts.
Does it matter? Does the z-troller have a DC voltage regulator inside it? If so, what is its regulated output voltage?
From what I've read, the usual rule-of-thumb advice for regulated voltage is not to exceed the regulated output by more than ~50% on the input side. So, for example, if the z-troller uses 3 volts internally by means of an internal voltage regulator, then 8.5 to 9 volts on the input is possibly creating a lot of heat burden inside the z-troller.
I don't mind switching over to a regulated 5 volt power supply for each of my z-trollers if it means the z-trollers will last longer--especially now that the z-trollers are sold out and won't be made anymore.
