Does the latest z-net have the ability to use POE?
POE?
Any RPi can be powered by a POE connection.
Historically here have used the TP-Link power splitters.
There was a mention of a small footprint POE splitter on Amazon a couple of weeks ago relating to using the Dot or GV devices.
Actually your post has me purchasing one to test out....
UCTRONICS IEEE 802.3af Micro USB Active PoE Splitter Power Over Ethernet 48V to 5V 2.4A for Tablets, Dropcam or Raspberry Pi (48V to 5V 2.4A)- Pete
Auto matorHomeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb
HS4 Pro - Ubuntu 22.04 / Lenova Tiny M900 / 32Gb Ram
HSTouch on Intel tabletop tablets (Jogglers) - Asus AIO - Windows 11X10, UPB, Zigbee, ZWave and Wifi MQTT automation-Tasmota-Espurna. OmniPro 2, Russound zoned audio, Alexa, Cheaper RFID, W800 and Home Assistant
Yes.
Here power my tabletop touch tablets and remote RPi's with standard POE ==> POE 5VDC splitter like the one's mentioned above. (here use TP-Link).- Pete
Originally posted by Rvtravlr View PostI think I've answered my own question, but just to make sure. I have Unifi switches which are 802.3af/at POE+. By plugging the above described devices into one of my switches, I can then get 5 volts to the Z-net?
Thanks for the replies.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
https://www.amazon.com/WT-AT-8-56v12...01IODMBRY?th=1
IF anyone reads this, consider getting the at version in case you want to use PoE+ devices as well. If you get the af version, you can still use the same injector for PoE+, but you have to get the bigger power supply. I think this is great for someone who doesn't want to use a PoE switch but still has some PoE devices. I use it in conjunction with a 24 port switch (the injector ss in the top right of the SMC. I've attached an image of it).
I have not had issues over the years with the TP-Link power splitters. Started initial POE for touchscreens (7 watts) using a Tycon POE 5VDC splitter.
Never did worry here about the RPi using POE.
I like the footprint of the new ones.
Here are some pictures:
Tycon POE power splitter
[ATTACH]65961[/ATTACH]
TPLink POE power splitter - here installed one for OpenWRT micro router inside of Leviton Omni Pro 2 panel this past year.
[ATTACH]65962[/ATTACH]
This is the smallest POE splitter I have seen to date.
[ATTACH]65963[/ATTACH]- Pete
