Hi,
I have a Z-net that have been working perfectly since I got it, until now!. Now it has started to suddenly shut down(?). Making my home setup unusable. Since I'm controlling everything as lights, heat, security, it is kind of a big deal!
Just like that, the Z-net just stops to respond:
okt-21 09:51:47 Z-Wave Warning Z-NET: Cannot connect to Z-Wave Ethernet at IP 192.168.1.158 port: 2001, Ex=Et connection attempt failed because the connected party did not respond correctly after a period of time or the established connection failed because the connected host did not answer 192.168.1.158:2001
okt-21 09:51:21 Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.1.158...
okt-21 09:51:21 Z-Wave Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
I don't have 2 systems running. If I check the Z-net, there is only a red light on the box.
If I disconnect the power and re-plug it, it then starts and work fine for a few minutes. But then disconnects again!
I'm using LAN cable and the power source that came with the Z-net.
I have cheked that the Z-net has the latest firmware.
Version 1.0.23
Please advice me with further actions!
Heat controll is a big issue atm...
Version 1.0.23
