I have three Z-Nets all connecting to Homeseer using wifi and fairly often one will lose its identity from find.homeseer and Homeseer automatically reconnects to one of the other wifi interfaces with poor signal and bad results. I have tried using DHCP for the Z-nets and reserved their IPs with the routers as well as trying static IP for the Z-Nets with similar results. Only way to restore things is to reboot the Z-net, then disable the interface and then reenable the interface. Network is robust with good signal and no DHCP conflicts. When the offending Z-Net is not found by find.homeseer, I can still ping it and I can still access its webpage. All Z-nets are version 1.0.23.
As an example, the attached image shows what happens when I lose Z-Net DadsRoom from find.homeseer. It reconnects to Kitchenwifi interface.
Any help appreciated.
