Upgrade to Z-Net. Unable to restore backup.
    #46
    Thanks for the conversion script. Worked great for my Z-Stick S2 to Gen5 upgrade. Never noticed the pluging let's you backup all you want but not restore.
    Very happy now.
      #47
      Can someone help fill in the gaps please.
      Have followed zwolfpack post #37
      How do I run the script on the z-wave backup to generate the bin file for the Aotec Z-stick tool.
      Trying to replace a flacky z-wave.me with aotec on a win 10 server with HS4Pro
      Looked at the Zensys tools but cannot get any sense out of it.
      Think I might be getting too old for this tech, either that or lockdown is scrambling what brain I have.
        #48
        I never posted the detailed procedure because the other poster figured it out on his own. From post #37
        1. Download Perl: http://strawberryperl.com/download/5....0.1-64bit.msi. Run the installer, answering all prompts with the default answer.
        2. Download Aeotec Z-Stick Gen5 Backup Tool to your Downloads folder. Unzip this, will create folder "Z-Stick Gen5 Backup Tool"
        3. Download the script archive from post #14. Open this and copy the file named ZWave-to-zme.pl to the "Z-Stick Gen5 Backup Tool" folder created in step (2).
        4. Locate the Z-Wave backup you want to restore. These are in the Data/Z-Wave folder under the HS3/4 application root. It'll have a .ZWave extension. Copy this file to the "Z-Stick Gen5 Backup Tool" folder as well.
        5. Open a Windows cmd shell (from Windows search, enter 'cmd' and select 'Command Prompt application') and navigate to the "Z-Stick Gen5 Backup Tool" folder from step (2): commands cd Downloads; cd "Z-Stick Gen5 Backup Tool"
        6. Run the ZWave-to-zme.pl script: command perl ZWave-to-zme.pl Your_backup.ZWave replacing Your_backup.ZWave with the file copied in step (3). This will create memory image file Your_backup.ZWave.bin
        7. Make sure your new controller device is in place. Determine what COM port it is on, and ensure that its not connected in the Z-Wave plugin.
        8. Start the Aeotec application: command zwave_500.exe ... Aeotec GUI will open.
        9. Select Settings->Port and select the COM port of your new device. Message 'Load ZStick Success' should appear at the bottom.
        10. Select 'Write EPROM'. This opens a file chooser; navigate and select the Your_backup.ZWave.bin file created in step (6).
        11. On completion popup 'Eeprom Write Finish ... ' appears ... you're done!
          #49
          Thank you that sorted it.
          It was the PERL command that got me.
