I am still trying to diagnose blockages that occur in my Z-Net periodically where multiple commands appear to get stuck in there and then suddenly show up in Homeseer 30 second later.
As part of doing this it was suggested that I turn Enable Polling off. In doing this I find that a number of my events don't work so I am digging into this.
For example I have a Leviton switch at my basement door. When it is turned on I trigger events to turn on more lights in the basement. The configuration of this switch is attached to the message. I was under the impression it was an instant status reporting switch.
With Enable Polling turned on the events run fine. If I turn off Enable Polling then Homeseer doesn't see the switch turn on or off. So does Enable Polling need to be turned on in order to catch the instant status updates from Z-wave devices that support this?
Thanks for the help.
