how to get extra data store for a z-wave device
  • how to get extra data store for a z-wave device
    I have a z-wave blind controller and I need to get at the information that (I think) is stored in the extra data store which is shown on the advanced tab to have 37 named entries. Is there a way to find out what these named entries are and what values they have?
    You would have to write a script to read them. They are just name/value pairs of data.
    This code will read the root device and all child devices, dumping PED if there are any available:
    PHP Code:
    Public Sub DumpPed()
    Dim d As Integer 0
            Dim y
    As Integer
            Dim pk
    () As String
            Dim s
    lin As String
            Dim dev
    pDev As Scheduler.Classes.DeviceClass
            Dim assocDevices
    () As Integer
            Dim PData
    As clsPlugExtraData Nothing
            pDev
    hs.GetDeviceByRef(gparentDeviceRef)
    assocDevices pDev.AssociatedDevices(hs)
            For
    0 To assocDevices.Count 1
                dev
    hs.GetDeviceByRef(assocDevices(y))
                If (
    dev IsNot NothingThen
                    lin
    dev.Ref(hs) & " " dev.Name(hs)
    PData dev.PlugExtraData_Get(hs)
                    If (
    PData IsNot NothingThen
                        pk
    PData.GetNamedKeys()
                        For
    0 To pk.Length() - 1
                            s
    PData.GetNamed(pk(x))
    lin &= " pk=[" pk(x) & "]  val=[" "]"
    Next
                        Log
    (linLogType.LOG_TYPE_DEBUG)
    End If
    End If
    Next
        End Sub
      I'm having a problem with s = PData.GetNamed(pk(x)). The error is Conversion from type 'Byte()' to type 'String' is not valid. So, I'm assuming that GetNamed returns an array of bytes? I tried to find documentation on PlugExtraData_Get and GetNamed, but couldn't find it in the documentation.
        I have also tried having the return from GetNamed return an array of bytes, but that doesn't seem to be working either.
          Not sure - that code is from one of my plugins and seems to be working here...
            And any idea where to find documentation on GetNamed or PlugExtraData_Get? Where did you find out how to use it?
              Figured it out (and why your code works for you), the GetNamed returns whatever type that particular value is. Yours must all be strings, while mine are a variety of of types. Anyway, I should be able to make it work now. Thanks for the assist.
                Lots of debugging in Visual Studio
