I have events that are manually driven that turn off everything in a specific room. I use them in conjunction with the main light switch so that as you leave a room, a triple tap shuts EVERYTHING off. They work pretty fast or fast enough. SO, I created an event that when a switch at the bottom of the stairs is triple tapped, it goes room by room running these manual events. It takes FOREVER. Not 10 second. Not 30 seconds. Up to 3 minutes. I have run them manually and it takes less time to run them one at a time than it does all together. I get no error messages either way and I can see in the log that the command gets sent. ….but it can take 3 minutes for the device to turn off. It is not HORRIBLE. It always works...eventually. I am just wondering if there is a better way to accomplish this event. I originally set it up this way because I was adding things to different rooms on a regular basis. It allowed me to make ONE change and all other events would use that change. Seemed smart at the time.... Is it best practices? How is everyone else doing this sort of event?
I do have a couple of OLD 9.6 devices and a few non plus devices. I experimented with removing them from the events completely and with moving them to the end of the event. It only saved about 10 seconds when they were out completely. To me, that says they are not the problem.
Any words of wisdom?
Rob
Rob
